horrorshow
Lakewood Original
- Dec 14, 2007
I'll try to keep this short and simple, I downloaded "og" Oblivion, then used Wabbajack to install the modlist "Heartland Redux"
It works great EXCEPT it doesn't include a UI mod....
- So from what I can gather, Wabbajack basically creates an entirely separate mod folder and within it are all kinds of directory trees I'm not familiar with etc.
Now, just to install for example "Northern UI", what do I do??
(The install instructions on nexus say the usual "just plunk it in the Data folder", well the Heartland directory has no Data folder & my vanilla Oblivion directory has no OBSE folder within it's relative Data folder)
** Basically I'm befuddled, my google-fu has yielded nothing, and I don't wanna break this perfectly good modded install I have going
Please assist [H] & Many Thanks!!
EDIT: Ok, nevermind... Figured it out, just installed it via the Mod Organizer 2 exe within the Heartland Redux folder....
MODS PLEASE DELETE THIS THREAD - THANKS
