morpheus9394
- May 8, 2002
If I run my PC in its O/Ced state the PC will hang after a couple of minutes when encoding/decoding DIVX movies.
But if I ran any other benchmarks like Memtest or 3dmark 2003/2005 or play any games, the PC is stable.
Here are my O/C settings:
243fsb at 5:4 ratio (also tried 3:2 ratio but same problem)
Vcore at default 1.52v (tried raising to 1.6v and 1.65v but that didn't help)
DDR Voltage 2.8v
AGP at 1.55 (tried raising to 1.6v)
DDR timings currently at 2-3-3-7, tried going as low as 3-4-4-8 but same problem.
My GAT settings are Auto- Normal-Disable-Disable and Hyperthreading is enabled as is Dual Channel
The HDD each have their own SATA channel and the optical drives are also on their own channel.
PSU is a 430w True Power.
Heat is not a problem as I have a XP-120 and YS-Tech 120mm Fan with Arctic Silver 5 applied.
Temps are 44c idle and rise 55c during gameplay and go as high as 64c during encoding but this is not high for my system, it has gone as high as 75c when encoding a DVD to Divx in the past with no problems (remember actual temps are around 10c lower than the ones reported by ABIT EQ)
The SATA drives each have a 80mm case fan sharing the power and the optical drives have 2x80mm fans and the CPU fan sharing the power lead.
The 6800GT has its own power lead.
Memtest has done 3 passes with no errors in the O/Ced state.
The only thing I have not done is format and reload Windows, I am trying to avoid that as I have so much stuff installed, it will take me all day to get the machine setup again.
Does anyone have any tips or advice?
Thanks in advance and sorry for the longish post.
DDR Voltage 2.8v
