o/c setting not holding.
I've an opteron 144 and a evga sli board, and for some odd reason, the fsb and ram dividers do not hold to the bios values on reboot. anyone experienced this before? And if so, how to fix?
yea this happens to most evga boards. i bought the evga 7800gt w/ free motherboard twice, and got an nf41 and a nf43. had this prob with both. go to the thread here
http://www.hardforum.com/showthread.php?t=943238
for everything about this board. you will need a bios upgrade to correct your problem. even after the bios upgrade, about half of the boards will not retain bios settings if you set htt to 270 or over. there are also some ram/1t issues. you can also check the evga community at
http://www.evga.com/community/messageboard/forum.asp?FORUM_ID=26
aside from the above issues, this is a nice board. overclocks well, decent accessories, ok layout, stable.
good luck with yours.
