I'm ready to o/c my 2600k. Just got a new case...Lian Li Lancool. Currently I have an H50 setup cooling the cpu. I also have a Coolermaster 212 EVO new in the box. The cpu temps are decent when the case side panel is off but get toasty when the case is closed. I think this is because the H50 calls for the fan the blow air from the outside in which gives me three fans all blowing into the case. I'm considering o/cing but would like to improve the cooling setup first. I though that I might swap the h50 for the 212evo and put the fan on the rear of the case blowing air outside. This should create a constant airflow from front to back. Any thoughts or suggestions are appreciated.
