O/C help for the mobo challenged?
Monkey34
I know there is soft fsb for those with no bios option to o/c, but is there a software answer for those with no bios options for cpu volts,bus dividers,etc (like me)? the only option my t-bird mobo has is some fsb choices(in odd increments), and I cant get windows stable after 114/224 bus. temps and memory timings have no effect..it just wont go over this limit...its ROCK SOLID up to it tho.:confused:
