o/c and a failed wu question
Filter
if i make a back up of my folding forum at lets say 70% and fails at 80% and redownloads a new unit
can i just kill that folder and start over at 70% with the back up?
you could but i dont think you will get points for it since the client sends back the failed WU. so when you run it again it just shows up as a duplicate and gets discarded, but you can try.
yeah thats what i was afraid of.
It all depends on if the failed work-unit was sent back.
If it was sent back and you download a new work-unit then no.
If it was just deleted and you redownload the work-unit then yes.
But you won't know which one will happen untill it occures.
Luck ............ :D
[H]
so did this try and submit it or can i just use the back up?
Launch directory: C:\Users\Filter\Desktop\folding\SMP
Executable: C:\Users\Filter\Desktop\folding\FAH.exe
Arguments: -oneunit -forceasm -smp -bigadv
[06:22:26] - Ask before connecting: No
[06:22:26] - User name: Filter (Team 33)
[06:22:26] - User ID: xxxxxxxxxxxxxxxxxxx
[06:22:26] - Machine ID: 2
[06:22:26]
[06:22:27] Loaded queue successfully.
[06:22:27]
[06:22:27] + Processing work unit
[06:22:27] Core required: FahCore_a3.exe
[06:22:27] Core found.
[06:22:27] Working on queue slot 01 [December 21 06:22:27 UTC]
[06:22:27] + Working ...
[06:22:27]
[06:22:27] *------------------------------*
[06:22:27] Folding@Home Gromacs SMP Core
[06:22:27] Version 2.22 (Mar 12, 2010)
[06:22:27]
[06:22:27] Preparing to commence simulation
[06:22:27] - Ensuring status. Please wait.
[06:22:36] - Assembly optimizations manually forced on.
[06:22:36] - Not checking prior termination.
[06:22:40] - Expanded 24862172 -> 30796293 (decompressed 123.8 percent)
[06:22:40] Called DecompressByteArray: compressed_data_size=24862172 data_size=30796293, decompressed_data_size=30796293 diff=0
[06:22:40] - Digital signature verified
[06:22:40]
[06:22:40] Project: 6900 (Run 11, Clone 6, Gen 12)
[06:22:40]
[06:22:40] Assembly optimizations on if available.
[06:22:40] Entering M.D.
[06:22:46] Using Gromacs checkpoints
[06:22:50] Resuming from checkpoint
[06:22:50] Verified work/wudata_01.log
[06:22:50] Verified work/wudata_01.trr
[06:22:50] Verified work/wudata_01.xtc
[06:22:50] Verified work/wudata_01.edr
[06:22:51] Completed 52410 out of 250000 steps (20%)
[06:23:36] Completed 52500 out of 250000 steps (21%)
[06:44:57] Completed 55000 out of 250000 steps (22%)
[07:05:39] Completed 57500 out of 250000 steps (23%)
[07:26:10] Completed 60000 out of 250000 steps (24%)
[07:47:00] Completed 62500 out of 250000 steps (25%)
[08:07:36] Completed 65000 out of 250000 steps (26%)
[08:28:09] Completed 67500 out of 250000 steps (27%)
[08:48:45] Completed 70000 out of 250000 steps (28%)
[09:09:20] Completed 72500 out of 250000 steps (29%)
[09:29:55] Completed 75000 out of 250000 steps (30%)
[09:50:33] Completed 77500 out of 250000 steps (31%)
[10:11:06] Completed 80000 out of 250000 steps (32%)
[10:31:36] Completed 82500 out of 250000 steps (33%)
[10:52:37] Completed 85000 out of 250000 steps (34%)
[11:13:11] Completed 87500 out of 250000 steps (35%)
[11:33:42] Completed 90000 out of 250000 steps (36%)
[11:54:15] Completed 92500 out of 250000 steps (37%)
[12:14:47] Completed 95000 out of 250000 steps (38%)
[12:35:19] Completed 97500 out of 250000 steps (39%)
[12:55:51] Completed 100000 out of 250000 steps (40%)
[13:16:24] Completed 102500 out of 250000 steps (41%)
[13:36:56] Completed 105000 out of 250000 steps (42%)
[13:57:31] Completed 107500 out of 250000 steps (43%)
[14:18:02] Completed 110000 out of 250000 steps (44%)
[14:38:34] Completed 112500 out of 250000 steps (45%)
[14:59:06] Completed 115000 out of 250000 steps (46%)
[15:19:36] Completed 117500 out of 250000 steps (47%)
[15:40:07] Completed 120000 out of 250000 steps (48%)
[16:00:38] Completed 122500 out of 250000 steps (49%)
[16:22:11] Completed 125000 out of 250000 steps (50%)
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [December 21 16:35:27 UTC]
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.30
http://folding.stanford.edu
[16:35:27] - Ask before connecting: No
[16:35:27] - User name: Filter (Team 33)
[16:35:27] - User ID: xxxxxxxxxxxxxxxxxxxxxx
[16:35:27] - Machine ID: 2
[16:35:27]
[16:35:27] Loaded queue successfully.
[16:35:27]
[16:35:27] + Processing work unit
[16:35:27] Core required: FahCore_a3.exe
[16:35:27] Core found.
[16:35:27] Working on queue slot 01 [December 21 16:35:27 UTC]
[16:35:27] + Working ...
[16:35:27]
[16:35:27] *------------------------------*
[16:35:27] Folding@Home Gromacs SMP Core
[16:35:27] Version 2.22 (Mar 12, 2010)
[16:35:27]
[16:35:27] Preparing to commence simulation
[16:35:27] - Ensuring status. Please wait.
[16:35:37] - Assembly optimizations manually forced on.
[16:35:37] - Not checking prior termination.
[16:35:41] - Expanded 24862172 -> 30796293 (decompressed 123.8 percent)
[16:35:41] Called DecompressByteArray: compressed_data_size=24862172 data_size=30796293, decompressed_data_size=30796293 diff=0
[16:35:41] - Digital signature verified
[16:35:41]
[16:35:41] Project: 6900 (Run 11, Clone 6, Gen 12)
[16:35:41]
[16:35:41] Assembly optimizations on if available.
[16:35:41] Entering M.D.
[16:35:47] Using Gromacs checkpoints
[16:35:53] Resuming from checkpoint
[16:35:53] Verified work/wudata_01.log
[16:35:53] File work/wudata_01.trr has changed since last checkpoint
[16:35:53] mdrun returned 3
[16:35:53] Gromacs detected an invalid checkpoint. Restarting...
[16:35:55] Folding@home Core Shutdown: UNKNOWN_ERROR
[16:35:58] CoreStatus = 62 (98)
[16:35:58] + Restarting core (settings changed)
[16:35:58]
[16:35:58] + Processing work unit
[16:35:58] Core required: FahCore_a3.exe
[16:35:58] Core found.
[16:35:58] Working on queue slot 01 [December 21 16:35:58 UTC]
[16:35:58] + Working ...
[16:35:58]
[16:35:58] *------------------------------*
[16:35:58] Folding@Home Gromacs SMP Core
[16:35:58] Version 2.22 (Mar 12, 2010)
[16:35:58]
[16:35:58] Preparing to commence simulation
[16:35:58] - Assembly optimizations manually forced on.
[16:35:58] - Not checking prior termination.
[16:36:02] - Expanded 24862172 -> 30796293 (decompressed 123.8 percent)
[16:36:02] Called DecompressByteArray: compressed_data_size=24862172 data_size=30796293, decompressed_data_size=30796293 diff=0
[16:36:02] - Digital signature verified
[16:36:02]
[16:36:02] Project: 6900 (Run 11, Clone 6, Gen 12)
[16:36:02]
[16:36:02] Assembly optimizations on if available.
[16:36:02] Entering M.D.
[16:36:10] Completed 0 out of 250000 steps (0%)
[16:57:33] Completed 2500 out of 250000 steps (1%)
[17:18:09] Completed 5000 out of 250000 steps (2%)
--- Opening Log file [December 21 17:29:10 UTC]
[17:29:10] - Ask before connecting: No
[17:29:10] - User name: Filter (Team 33)
[17:29:10] - User ID:xxxxxxxxxxxxxxxxxxxxxxxxxx
[17:29:10] - Machine ID: 2
[17:29:10]
[17:29:10] Loaded queue successfully.
[17:29:10]
[17:29:10] + Processing work unit
[17:29:10] Core required: FahCore_a3.exe
[17:29:10] Core found.
[17:29:10] Working on queue slot 01 [December 21 17:29:10 UTC]
[17:29:10] + Working ...
[17:29:10]
[17:29:10] *------------------------------*
[17:29:10] Folding@Home Gromacs SMP Core
[17:29:10] Version 2.22 (Mar 12, 2010)
[17:29:10]
[17:29:10] Preparing to commence simulation
[17:29:10] - Ensuring status. Please wait.
[17:29:20] - Assembly optimizations manually forced on.
[17:29:20] - Not checking prior termination.
[17:29:23] - Expanded 24862172 -> 30796293 (decompressed 123.8 percent)
[17:29:23] Called DecompressByteArray: compressed_data_size=24862172 data_size=30796293, decompressed_data_size=30796293 diff=0
[17:29:23] - Digital signature verified
[17:29:23]
[17:29:23] Project: 6900 (Run 11, Clone 6, Gen 12)
[17:29:23]
[17:29:24] Assembly optimizations on if available.
[17:29:24] Entering M.D.
[17:29:30] Using Gromacs checkpoints
[17:29:35] Resuming from checkpoint
[17:29:35] Verified work/wudata_01.log
[17:29:35] Verified work/wudata_01.trr
[17:29:35] Verified work/wudata_01.xtc
[17:29:35] Verified work/wudata_01.edr
[17:29:36] Completed 6095 out of 250000 steps (2%)
