There are two fans installed in the Vulcan case, a 120mm top exhaust and a 120mm front intake. The front fan works fine, but for some reason the top fan won't spin. At first I had them plugged into the integrated fan controller of the case. It wasn't spinning up so I tried plugging it directly into the motherboard. As soon as I plugged it in the fan started spinning but immediately stopped again (like it just had just had one burst of energy, then the momentum kept it spinning a few more rotations before stopping.) So then I borrowed a molex adaptor from another case so that I could plug the Vulcan's case fan directly into a molex, but it did the same thing: started spinning but immediately quit.
I'm out of ideas now
Since there are only two fans, and I need to cool a pretty hot motherboard/cpu/gpu I should probably work this out before using it! All advice would be hugely appreciated!
