I'm finally starting my watercooling build using the NZXT Switch 810 case as my base. Here is the current list of components/things I ordered that might not get used:
1 x EK Supreme HF (Acetal + EN)
2 x EK 580GTX VGA Block (Acetal + EN)
1 x Phobya G-Changer 420mm
1 x Phobya G-Changer 140mm
8 x SilverStone AP141 140mm Fans
4 x Akasa 140mm LED Fan
1 x Scythe Kaze Q-12
2 x PrimoChill Anti-Kink Coils
2 x PrimoChill 1/2" ID 3/4" OD White Tubing
2 x Silver Kill Coil
1 x EK Res 150
1 x Swiftech MCP35X2 White
1 x Swiftech MCP35X Heat Sink (will try to make it work until the real heatsink comes out)
1 x Nexus 120mm to 80mm Fan Adapter (might use this to mount heatsink)
1 x Bitspower 90-degree compression fitting
1 x Bitspower D-plug set
8 x Bitspower compression fitting
8 x 45-degree compression fitting
2x Bitspower sealing plug
1 x Phobya Hose Cutter
3 x Phobya Rad Screws
4 x Lamptron Clamps
1 x 10-pack Danger Den White Clamps
1 x Remote power for PSU
1 x Arctic Silver Non-Conductive
1 x PrimoChill Funnel (so tiny)
1 x NZXT White LED Cable 2m
Picture of components:
Current case configuration:
Next up is cleaning the watercooling components. Then I start mounting things in the case. It will probably take me a while to route everything as I'll have 3 video cards (third is for the two 20" monitors for PLP) and 12 fans total. I might end up getting a fully modular power supply because I have 2 extra cables that I don't use with this one just taking up space. Any suggestions before I really get started?
1 x EK Res 150
4 x Lamptron Clamps
