http://www.nzxt.com/product/detail/137-source-530-full-tower-computer-case.html
All set at the price of $89.99
Look for it at your local retailer or NZXT Armory.
https://store.nzxt.com/ProductDetails.asp?ProductCode=CA-SO530-M1
It is available NOW!!!!!!!!
- A full Tower Case
Cooling Features - Front - 2x 120mm/140mm fans or 1 x 200mm. It will fit a 120mm/140mm/200mm/240mm/280mm Rads
- Rear - 1x 120mm/140mm fans (1x120mm included). It will fit 120mm/140mm Rads
- Bottom - 2x 120mm Fans. It will fit 120mm/240mm Rads
- Top - 3x 120mm fans (1x120mm included). 2x 140mm fans. It will fit a 120mm/140mm//240mm/280mm/360mm Rads
- Pivot - 1x 120mm/140mm fan
Clearance - CPU Cooler - 282mm with Pivot Fan
- VGA Card 310mm (With Cage)/ 444mm (Without Cage)
- Cable Management 26mm (Lowest Point)/ 34mm (Highest Point)
Dimensions - 235mm x 507mm x 510.5mm
Material - Steel, Plastic, Mesh
Motherboard Support - ITX, Micro-ATX, ATX, EATX (322x272mm)
Expansion slots - 8
External Electronics - 1x Audio/Mic
- 2x USB 3.0
Warranty - 2 years
Kraken Support - It will fit the Kraken X40 and X60 units
