I'm looking to purchase either the NZXT S340 Elite or the Phanteks Eclipse P400S very soon. My current case is a Rosewill Redbone, and my system consists of:
i7-4770K
ASRock Z87 Pro 3 Motherboard
Cooler Master Seidon 120M AIO cooler
32gb DDR3
HIS Radeon HD 7970 IceQ X
Intel 730 480gb SSD
LG 12x Blu-ray Drive
3x 3.5" HDD (1x 1TB, 1x 3TB, and 1x 4TB)
The Redbone is a pretty nice case, but I've been trying to reduce my system temperatures by adding case fans lately with only marginally better temperatures. It's really time to upgrade the case.
I know that I'll have to give up my Blu-ray drive with either one of these cases, but I have an ASUS USB 3.0 external 12x Blu-ray burner that I purchased a little over a year ago on a whim that I've never used. I hate to add to the clutter of my desk with an external Blu-ray drive, but I'm sure I can live with it. I'll have to as I still use my drive quite a bit.
I'd really like input from owners of these cases--especially those that may have had both of these cases at one time or another. Tell me what you like or don't like after "living" in this case for a while.
Here are my pros/cons:
NZXT S340 Elite:
Pro:
+ Asthetics -- This is the best looking case of the two (I like straight lines rather than curved or angular)
+ Size -- I like the size of the case (part of which is the front face is flat)
+ Extras -- magnetic puck is nice (although I don't really know that I'll use it)
+ Placement of top/front USB 3.0 ports
+ Cut outs in PSU shroud for cable routing
Con:
- No DVD/Blu-Ray Drive support (neither case has this)
- Limited 3.5" HDD Mounts (holds 2 in the bracket, with 1 mounted on the PSU shroud). I'm afraid having the drives stacked like this may cause them to run too hot. Plus, I can't add any more HDDs than I've already got.
- Cable management clips -- I'm not sure how well these will hold based on some of the reviews.
- No dust filter on top of case
Phanteks P400S:
Pro:
+ 3.5" HDD tray holds 2x -- Plus, 4 more HDD trays can be added (not sure of the cost of these)
+ Cable management -- velco straps look like they'll stay in place better
+ Room in from of case (without additional HDD trays)
+ Extras -- LED lighting built in.
Con:
- Asethetics -- I'm not a big fan of the angular/curved front, but maybe it would grow on me. I don't like that it angles out at the bottom.
- Can only handle 2x 3.5" HDD out of the box -- additional trays at an additional cost
- Cut outs in PSU shroud are not as big or located as well as the S340
- Addition of extra 3.5" HDD trays will block front fans
I would really like to hear from anyone that has either one of these cases and regrets getting it--would just like to hear about anything that just really bothered you once you started using it for your system.
i7-4770K
32gb DDR3
Intel 730 480gb SSD
NZXT S340 Elite:
Pro:
Con:
Phanteks P400S:
Pro:
Con:
