NZXT Phantom OR CM HAF-X ?
amit_talkin
hi ppl,
well , you might gonna say to search google for the title question, but believe me, i did it already and i m still confused! . So I am asking for your help with my requirements.
I want to buy a case which can..
1. hold 360mm radiator.
2. more spacious and should hold reservoir and mcp655 pump.
3. airflow and cooling at its best among these 2.
4. should not get dusty easily.
5. easily mod-able.
more good features always welcome!
I am not gonna upgrade in future atleast 3 years. so please advice accordingly.:cool:
do you want the 360 rad internal? the phantom will only house a rad as big as 2x140 from what i gathered. i really like the phantom and almost bought it, but the lack of internal watercooling (even with extreme modding) made me choose other wise (got a silverstone rv01).
id take a phantom over a haf x though, but i think you can fit a 360 rad internally on the haf x.
Yes, phantom can hold only 2x120mm radiator. There is some space in phantom inside for 360mm , but no mounting holes for it. So i would better go for HAF-X :).
