NZXT Lexa
remarkc
Does anyone have any experience with this case? I have been looking at buying one and would like some opinions before I do. Thanks
yeah I've had that case for like 2 years, its not bad, the hdd power led is fuckin glaringly bright so instead I connected it to the hdd activity and it looked pretty kickass, if you plan on putting alot of high end components in it you might wanna reconsider, it doesnt have bad air flow but the stock fans dont move alot of air, I just switched yesterday to the cm cosmos, over all I loved the aesthetics of the case, if it appeals to you I say get it man.:D
I've worked with the Blackline version of the case (Steel construction, black plastic, red lighting). Cable routing options are poor, so you'll have cables showing no matter what. In terms of size, its slightly longer than an Antec Sonata III internally, so it should be able to fit 8800GTX-sized cards decently. The round plastic 'cage' at the back gets in the way if you need to open the case up. If the case isn't going to be on top of a desk, then you might as well leave it off.
on top of that, if you plan to watercool, you'll have to take the cable management system that Leman mentioned, as the radiator wont mount on the back with it on, an when I had my thermaltake big water on there, I had to drill holes to mount the radiator on the back, otherwise it wouldve mounted crooked
