I've got an S340 Elite case, and I'm trying to figure out if I should go for the X62 (280mm) cooler, or X42 (140mm).. It might seem like a silly question, but my reasoning on this is that I'm concerned about enough cool air coming into my case.
My case has room for 2 140mm fans in the front, so I could run either the 280mm rad with the two fans with no problem, but I could also run the 140mm rad in the top location, and then a 140mm fan below it.
The X42 rad (140mm) seems to do pretty well at cooling the processor in the reviews I've read.
I'm just concerned about my graphics card, and part of me wonders if overall I'd be better off having the extra airflow of a free flowing bottom front fan, and then just the rad in the top front fan location..
Does anyone have experience with NZXT rads? How much airflow comes through the rad with the supplied rad fans? Enough for cooling the graphics card? Does it make more sense to just go for the 280mm?
I don't want this to potentially turn into a front mount rads are bad discussion either.. Believe it or not a front mount fan has merits over a top mount, because a front mount is pulling in cool air from the front of the case, a top mount is pulling in warm air from warm stuff inside the case. It is true that the top mount rad is then expelling air out of the case, and that the front mount one is expelling that into the case, but in the testing I've seen online both seem to perform pretty equally.
Comparison video:
Comparison video:
