Bluehosebone311
- Jul 21, 2013
I am currently in the process of building a new PC and using water cooling for the first time in the form of a NZXT Kraken X40 on a MSI Gaming Z87 GD65 board. The power for the X40 pump and the radiator fan uses a 3 pin connector that must be connected to the CPU fan header (no auxiliary power - everything runs off of this 3 pin connector). I know how to connect a 3 pin to a four pin CPU fan header - my question is this:
1.) Every review/overview has stated that I need to make sure the CPU fan header is running at a constant 12V so that the pump gets full power (see here: . First of all, shouldn't that be automatically the case as I am connecting a 3 pin power connector to 4 pin connector? With no pwm, isn't the default full power all the time?
2.) If I do need to check on this, how do I do this from the BIOS? Do I need to simply switch the CPU fan control to manual and set it to 100% - is that the same as making sure the voltage is constant?
