NZXT Kraken review query
Quartz-1
Has anyone done a review of the Kraken which compares cooling results with different sizes of AIO cooler?
I would like to see how a 80mm cooler compares with 92mm, 120mm, and 180mm coolers. Not only thermals but noise.
Perhaps this is something that might interest [H]?
It would be awesome if you could actually order one with a shipping timeframe. I bet when they manufacture more of them....there will be more reviews.
what do you mean?. Kraken X40?. Kraken X60?. where are you looing for that 80mm size?.. kraken x40 its 140mm. kraken x60 its 280mm.. there are TONS of review.. you simply can not compare a 280mm AIO water cooler kits with average air coolers, well known that highest-end air coolers(dual towers with 140mm fans) are barely on pair with 240mm radiator AIO WC kits being this last always able to outperform in cooling performance but at a little higher noise penalty.. 280mm radiators AIO WC kits have most of the 240mm AIO WC Kits cooling performance but at a way lower noise performance due to the bigger 140mm fan..
actually one of the best 240mm/280mm radiator water cooler in the market its the Swiftech H220 followed pretty close by the Corsair H100i, Silverstone Tundra TD-02, Corsair H110, NZXT kraken X60 and thermaltake water 3.0..
in the [H] Review of the kraken X60 we can see that when overclocked Silverstone HE-01 (for some people the best Air cooler in market). they are very paired cooling.. with less than 1C of difference..
No, I'm asking after the NZXT Kraken, which mods any compatible AIO CPU cooler into a GPU cooler
then you should specify that you are asking for the NZXT Kraken G10 mounting bracket..
