NZXT Gamma $34.99 shipped...
wol-va-rine
the Gamma is now only $34.99 shipped on Amazon, seems like a pretty hot deal for anyone needing a decent case, the only drawback is that it comes with only one 120mm fan...
NZXT GAMMA for $34.99
from what I've read it doesn't look quite as hideous in person, this is a temp case until I get my 600T SE, I just really need the rotated drive bays, and yes, it is definitely not my style, but once I get my 600T SE my kids will probably love how it looks when it becomes their case...
I wish more manufacturers were making cases like this....except without the horrible plastic surgery
This is a GREAT case for the price, and the aesthetics are subjective. The cable management alone is worth the price.
It's really not a bad looking case up close. I used one for my roommate's computer. Cable management is good and lots of places for getting your fans set up just the way you like. The whole thing feels pretty sturdy and I like the black interior. There's a cutout at the bottom of the case with a fan filter for the psu to get cooler air from the outside. I only wish that there was a filter in the front and maybe the side.
technically there is a filter on the front, but it can't really do it's job because it's separated from the front intake fan (I believe on the bottom most angled part of the front bezel)...
It looks like a great case, but I'm a huge fan of "form follows function" and don't like useless pieces of plastic sticking out all over.
I don't even consider that a filter because it, like you said, doesn't do anything. The vast majority of the air comes in from the holes on the sides because there's less resistance. They could've easily put the filter behind the plastic honeycomb.
well the "form follows function" Antec 300 is $25 more at the moment and doesn't have the rotated drive bays or the cable management features, I love the Antec 300 (my main case right now), it is simple and yet stylish (jmo) but the more I add to my rig and the more I have to go inside and do things the more I realize that I NEED rotated drive bays and cable management options, so until I get my 600T SE I need a cheapo case that does the trick until I can get a good deal on my aforementioned dream case...
I'm gonna give this a shot and then pass it on as the kids' case when the time comes...
+1
The Gamma is by far one of the best available for the price. Its looks are definitely tolerable in person. Pictures make it look way uglier than it actually is.
I have several nzxt cases and although they are all ugly there function as far as cooling is exceptional and the quality is pretty good not as good as my 800d's but hay it's way cheaper and I'm in for one.
the gamma isnt bad looking at all.
you can even buy the side panel with a window from the nzxt M59 which swaps over perfectly.
the only problem i had is it friggin fried my onboard sound :(
the only problem i had is it friggin friend my onboard sound :(
don't blame it on the case, butter-fingers!
NZXT's weird looking cases (a la Gamma, Beta, Lexa) all seem to grow on you as you see and use them in real life. I have the Lexa S, and after removing the front face (which was horrid IMHO), it has a lot of character with the red and blue LEDs of a fan controller and a memory stick in the side. I personally like the Beta a lot because it has six fan mounting spots, it looks gnarly, you can mount the PSU to suck air from the bottom, black interior, I own the Lexa, and both have similar build quality from the looks of it. If you're on a budget, I wouldn't be afraid to use one of the entry level cases as a starting point, then add your own fans, etc.
It looks like a decent case to me, especially for the price. I don't understand why all you guys are complaining for $35 shipped.
Great case for the price. My old NZXT case is of the same build quality of my new Antec one.
i dont think it looks bad at all. and those features for the price are incredible. they must be taking a huge loss on that. imo the cm cosmos is ugly.
they have to be clearing stock, they just have to be, the shipping alone means they can't be making much, if anything, on that case...
The sideways drive bays have to be nice. The location of the front usb ports is a bit low, but the location will also prevent breaking the usb port/plugs to a certain degree. Wish they'd design usb ports to internalize the plug, so that it wasn't so easy to snag and break.
I have owned 3 of these and they have been great. Very good case for the money.
Damn it ... I had to buy one ... meets 99% of my criteria ... but too cheap to pass up.
lol, this case has jumped up in price, a whole dollar, still only $35.99 shipped, I actually canceled mine (it wouldn't let me do it online, had to call to cancel) because the sale I was waiting for finally happened (600T)...
I've got this case and it's great for the price! I'll try and post a pic tonight.
Where's the sale for the 600T?
Just got mine in yesterday and installed my hardware into it. This case does have some really nice features for the pricerange. The way the HDD bays work is nice and the cable management is nice. I like my power supply on the bottom of the case drawing cool air from outside the case instead of hot air from inside the case.
Dislikes...Yes, it's ugly. Anyone who says otherwise, I sure wouldn't want to look at their wife. The gratings on the front that have to be removed for the optical drives are a PITA to get off. Only came with one 120mm fan and there is room for 5. The cheap ones on newegg are like $7 shipped, so if you're going to buy 4 more for max air flow, that really erodes the value of getting this cheap case.
not many "value" cases are gonna come with 4 fans...lol, I mentioned the lack of fans earlier though, but there's almost always a tradeoff in regards to "budget" cases, but for a basic customer build the lack of fans shouldn't really matter much (maybe add one more fan?) as temps should never really get that high...
do people even bother looking at local shops for prices on their budget cases? you wont find one for less than 50.. lol
the optical bay covers were easy as pie.. pinch the tabs and push..
again with the fans.. it says only 1 fan included.. plus you can always buy fans in bulk, or wait.. use the ones from your old case!
either way this is a awesome case.. does everything i need it to do and then some...
I literally had to break the optical bay cover on mine to remove it, no amount of pushing or pulling tabs was working. My old case had 90mm fans that were starting to vibrate excessively and get noisy, so I'm not compelled to reuse them. Fortunately, I did have an unused 120mm laying around.
The other case I had my eye on was the Cooler Master RC-600-KKN1-GP Gladiator 600 Mid Tower ATX Case for $60 shipped at Amazon. Since it's for a secondary computer that my wife mostly uses, I went with the cheaper $35 NXZT. I don't regret the purchase, but if I were going to buy four 120mm fans to put in this case making it $35 + $28, I would just have gotten the Cooler Master.
well dang.. mine were easy as heck.. lol
well like my mom always used to say, just because there's a hole there doesn't mean you have to fill it! so keep it in your pants mr. (your money that is lmao)
to everyone..
unless you have a mid/high end rig you won't need more than an exhaust fan.. or just swap it to an intake.. otherwise buy a fan or two.. not all 4 lol
if you were to buy three 120mm fans for the Cooler Master (which only comes with 1 more fan than the NZXT) it would still be ~ $20 more than the NZXT with the same number of fans in each case, no...? it's not like these more expensive budget cases are giving you 4 or 5 fans included in the deal, most only come with 2 (pretty much the standard for budget cases) and that's only 1 more than the NZXT...
do ya remember back in the day when one 120mm fan was all that was needed? good times. good times.
I used to use a 9800GX2, that effin GPU was 77C idle and 105C under load, so yeah I got into the habit of putting in as many fans as i could. It was great in the winter when it would heat the whole room. Not so bad now with the gtx 260.
