NZXT Classic M59 Esata
Soarin
Does anyone have this case at all? I do and for the life of me I cannot get the E sata working. I am not sure if it is my external enclosure or the esata port itself. I hooked the connector up correctly to my Mobo.
I plan on getting a HDD docking station and the one I am looking at supports E Sata and I want to take advantage of that.
The one on the front of the chassis? If it doesn't work, let me know via PM and we'll get something sorted out for you. I think the best way is to try and test it with another device, and make sure that port is enabled in your bios if need be (some bios may have it turned off).
Okay sweet. When I get home I will retest this. I will double check the BIOS. Also I will grab another esata to esata cord from local shop just in case.
I bought a new Esata cable and set the sata 2 ports of 2 and 3 to Esata and it is not working. I have the cable hooked to port 2 I think. I guess the next step is testing the internal sata cable going to Esata header
Any results? I want to make sure we get this figured out for you. :)
Nope I double checked it all and nothing. But again it could be the device I am using it self. I wont be able to get a external device until the end of this next week. Once I get one I will try again
Okie dokie. Please let me know when you can, I just want to make sure it's sorted.
