NZXT C1200 Platinum Review
Beaver LongTail
8-D
"Value and Conclusion​
  • The NZXT C1200 Platinum retails for around US$199.99/€199.99.
  • Overall quiet acoustic profile
  • Native ATX 3.1 and PCIe 5.1 compliance
  • Decent regulation and ripple control
  • High quality internals
  • Low cable and connector resistance
  • Ten-year warranty
  • No Molex connectors for legacy accessories
  • Very light load performance subpar against the competition
The NZXT C1200 Platinum steps up from their popular Gold-rated series with this 1200 W unit, which is equipped with native ATX 3.1 support and a dedicated 600 W PCIe 5.1 12V-2x6 connector. Designed with modern flagship graphics cards in mind, NZXT has maintained its signature clean aesthetic while partnering with a solid OEM to deliver robust internal components, including dual Rubycon 105 °C bulk capacitors, high-quality Japanese filter caps, and a sleek, compact chassis.
Performance on the test bench was impressive. The +12 V rail holds well under load, managing voltage drop across the cables to stay comfortably within ATX 3.1 specifications, and ripple is kept tightly controlled across the board. Acoustic performance is a highlight for this model; thanks to a relaxed fan curve, PWM control and a zero-RPM eco-mode, the unit remains quiet even when pushed to its limits. The modular cables also have pretty low electrical resistance, minimizing power losses and ensuring highly efficient current delivery to components.
Based on the results from our load testing, there aren't any major drawbacks we came across. Light-load efficiency is not the best we've seen in this category, but it is not terrible; a modern high-end PC idling generally will draw 60–90 W, so it's unlikely the 5 % result will ever be seen in the real world, which is good considering the voltage fluctuations as the PWM controller switches modes. Active power factor correction could also be improved with more modern controllers like those seen in the Corsair RM1200e (2nd gen), which hits 0.99 by 40% load, but the result here is perfectly acceptable and in line with most other options in this category. The complete omission of legacy Molex connectors might frustrate a small subset of users with older water-cooling pumps or fan hubs.
For the $199.99 MSRP, the NZXT C1200 Platinum offers excellent value in the 1200 W ATX 3.1 tier. It successfully improves on a highly capable internal platform, but sets itself apart with a significantly quieter acoustic profile than others, and signature NZXT styling. Despite the borderline efficiency margins, its outstanding power delivery, low cable resistance, and ten-year warranty make it a highly recommended, quiet powerhouse for enthusiast builds."
Source: https://www.techpowerup.com/review/nzxt-c1200-platinum/4.html
