Hello, my proscessor on my first build has been running hot lately, and I have been meaning to upgrade to water cooling for awhile, but my case does not have pre drilled holes an the only place the radiator will fit is where the exhaust fan, i would like to know where I should put it and where I should drill the holes.
My build
NZXT Apollo black mid-tower case
http://www.newegg.com/Product/Produc...=NZXT apollo
Radeon HD 6670 graphics card
Raidmax RX 530SS 530w PSU
16gb of veangeance DDR3 RAM
ASUS M5A97 AM3+ AMD Motherboard
an LG discdrive (got from bestbuy, dont know name but was cheaper)
AMD FX-4100 Zambezi 3.6GHz proscessor
and a SEAGATE 500gb harddrive
please look at the case, i will post my case as I have it in another post, the WC i want to get is here
http://www.newegg.com/Product/Produc...82E16835209049
I also would like to know if i could use it as exhaust, thanks!
My build
