ok, so I recently figured out that while our computers hold cd audio recorded at 44 kHz (if you got cd audio) when you go to playback that audio the audio is passed though a low-pass filter and downconverted to 20 kHz before coming out of your speakers.
I was a little dissapointed to learn that cd audio only represents the band from 20 kHz to 20 Hz. I figured 44 kHz = 44 kHz.
Basically how this works is that when they started to mess around with cd audio they were having a problem when they were recording audio they would get distortion on the playback
think of it this way, high frequencies such as harmonics may exceed the 44 kHz sampling rate and when recorded only are sampled at a fraction of what they actually represent (a continuous wave), instead you are getting at 44 kHz chopy blocks of high harmonic frequencies that when played back at the same sample rate of 44 kHz you get distortion. to solve the problem they cut the sample rate in half to make the audio sound acceptable w/ less distortion (eliminating the distortion would be impossible if I understand this correctly). so basically say that a 55 kHz tone is a harmonic of your recording and you record at 44 kHz then basically what happens is when that 55 kHz tone is being recorded on your 44 kHz system the entire wave is being undersupported by the sampling rate and thus the playback is sent down to 20 kHz to make you think you don't hear the remnants of the 55 kHz tone that was originally there. bascially what they are doing is reducing the prevalence of the vhf (very high freq.) tones in your playback so your brain doesn't percieve the effects of the alias affect.
interesting huh?
this is the only explanation i have found of why they half the sample rate.
is this correct?
so lets say these x characters represent your continuous 44 kHz recording
xxxxxxxxxxxxxxxxxxxxxx
with a sound of 55 kHz you would need more x's to represent that sound correctly (in it's full correct sound wave).
xxxxxxxxxxxxxxxxxxxxxx(xxxxxxxxxx) <-- these are not recorded (in fact the audio bits not recorded would be spread out over the entire wave to look something like this.) the () meaning dropped sound information your brain expects to hear
x(x)x(x)x(x)x(x)(x)x(x)x(x)(x)x(x)x(x)x(x)x(x) <-- just an example
basically the 44 kHz standard doesn't account for the 'space of sound,' only a fraction of it.
that's why dvd audio I guess is so nice.
interesting huh?
is this correct?
