Nylon Tubing?
Does anyone know if they actually sell this stuff in places like Home Depot? Where might you find this stuff other than Online Computer Modding Places. More specifically I'd like to find a place in Canada that sells this stuff in rolls.
neither Lowe's nor Home Deopt sells it. I went there today. Thats why Im resorting to these forums. Also I did a serach for nylon tubing on google and got nothing but porn. So Im clueless where I can get it. Xoxide is sold out of the black too.
Try a search for 'Expandable Sleeving'
https://www.cabletiesplus.com/Zgpurpose_details.cfm?TieID=2 has it for pretty cheap. http://www.action-electronics.com/jtxsleev.htm also isn't too expensive. You can get 1/8" for a great deal cheaper, but I personally found that too small
What size would you recommend for power supply cords? I not exactly sure if I should get 1/4, 3/8, or 1,2
Thanks for the help.
If you have a Fry's close by then go there. They have it in all sizes and colors as well as heat shrink to make it look good. Real cheap (cost) also.
PT
