NVsilencer 5 Question
xFuryofFivex
while i was reapplying thermal paste to the memory and gpu.. i left the metal standoffs and the cushion that goes between them in my lap... i got up quickly forget that they were there... i lost 1standoff and 1 cushion.... will the card work the same if just the 1 of each were missing.. im thinking of getting a new one.. just wanted to get some input on this situation
ok u see those 4 screw on standoffs
i dropped one and the black cushion that goes under it
I would assume those are important, especially since you need to apply even pressure.
yea,i was thinking that. for now i have the top 2 and the bottom left.. those seem to be more important,they cover the ram..
I say you have to start a search party in that couch. Go through it one last time.
Merc said:
Contact Arctic and have them send you a new one.
they would do that just for that small of a thing?
"I say you have to start a search party in that couch. Go through it one last time."
i looked a few times...ive moved to a new place since then...like a 2 weeks ago or so
