I am sure many of you have heard of the dreaded nvlddmkm.sys bug and the "display driver has stopped responding and has recovered successfully" error. Well, I am sad to say that I now have the problem and I cant seem to track it down. There was an interesting thread on these boards trying to find the root of this issue to no avail. There doesnt seem to be an answer out there as far as I know.
Anyways, I am not going to try and undertake the task of fixing the issue, I'm just going to try and avoid it as best as I can.
However, I have experienced artifacting every now and then for a while with my current card (8800GTX). Happened to me a little bit in Crysis and now in Vanguard. Over the past two weeks it has gotten really bad in Vanguard, and now I cant play for more than 10 minutes without BSOD or a system lockup and artifacting to boot.
http://williamb.dot5hosting.com//artifactv1.jpg
http://williamb.dot5hosting.com//artifactv2.jpg
Those are some pics of my artifacting.
What I am asking of you guys is if you think I should just go ahead and RMA my card. Its about 3 months old. I know a lot of people out there say RMA should be the very last step, but the fact that the problems have gotten worse in the past 2 weeks, and also the artifacting and nvlddmkm.sys happening together just scream faulty hardware to me. Sure they could both be due to the same issue, but the fact that it has gotten worse over time is what gets me.
I have tried lowering all my system clocks to stock speeds, removing and reinstalling several drivers, memtest, and several fixes I have found on various forums, and nothing seems to help.
I am probably going to try wiping and installing XP tonight...this will basically pinpoint faulty hardware yes?
specs:
Q6600 @ 2.4
EVGA 680i
8800GTX factory OC @ 621mhz
4gb mushkin at 5-4-4-12 2x2GB 1.8v
650W+550W dual PSU's
Vista 64
specs:
Q6600 @ 2.4
EVGA 680i
Vista 64
