JayteeBates
[H]ard|Poof
- Jul 21, 2007
So Fermi is here and it's performance is within the same ballpark as ATi currently. But the engineering at it's heart is radically different going for brute force "MOAR POWAH"!
So while they now have a card to compete with ATi - can they produce a next generation with the same philosophy? I say they cannot and I present you with what I consider the end of the brute force approach.
Now if we look at the history of transistor count in each gen from the G80 onward we see an increase of more than double the previous generation. So lets make some future predictions...
If we extrapolate the next generation NV product will have:
6,400,000,000 transistors
32nm fab process
The transistor count follows the trend and lets even give them the benefit of the doubt and assume they can manufacture it at the same process level intel does currently, 32nm. So that leaves us with a die size of approximately:
655 mm^2
Just doesn't seem feasible for them to continue down the current path. they are going to be forced to start a different approach be it either mimicing ATi's more modular design or some other path. The power requirements for a 655mm^2 die would be astronomical.
Code:
Core Card Fab Die Core Mem Bus Transistors Watts
(nm) (mm^2) (Mhz) (bits) (millions)
G80 GeForce 8800 Ultra 90 484 612 384 681 ?
GT200 GTX 280 55 576 602 512 1400 ?
GF100 GTX 480 40 529 700 384 3200 ?
32nm fab process
655 mm^2
