Nvidia USB stick miner
mkrohn
What are you guys using? after some googling this one seems pretty active KopiemTu. pimp apparently doesn't have an nvidia one yet but are working on it. I'm getting ready to order some 750ti's and I'm trying to figure out what USB stick I will be using since running full blown windows is just stupid.
Well, with regards to the stick itself. I'd go for the name brands (Sandisk,etc). My PNY sticks all started failing to boot at the exact same time (2months). My Sandisk ones have been strong.
I guess the good news is I have a ton of 8gb sticks now. They still work, but are finicky with the boot sector.
If pimp releases their nvidia one, I'd go for that as they designed it to have a minimum amount of writes.
I can say with near certainty that his question had nothing to do with the physical stick itself.
