Nvidia Surround Issues
Cecil
Spent the last few hours being dissapointed in my new surround setup.
Have two 660TIs in SLI, and three Dell S2440L monitors. Rest of the specs to eliminate questions, I7-3770K @ 4.5Ghz, 8GB 1866Mhz, 500GB Samsung 840 for game storage.
Nvidia 310.9 driver.
First I tried playing Far Cry 3. No matter what I try, I get stuttering when playing in surround. I disabled MSAA, set VSYNC and GPU frame rendering each to "1" which was the most playable setting. For the quality, doesnt matter if it was on low, medium, I was holding 58-60FPS with VSYNC on (high was in the 40s, very high about 30 with drops lower, and unplayable). But the movement wasnt smooth, and aiming very difficult.
I use Nvidia Inspector, and changed the SLI DX1x bit to a few different ones that are supposed to fix SLI issues. Didnt seem to do anything.
Then tried Borderlands 2. It doesnt seem to have any performance issues, and can max it out with VSYNC on fine. But the FOV is WAY off for the side screens. I can be looking at a building or object that would take me about 10 seconds to walk to on the middle screen, turn so its on one of the sides, and it makes it look so close, like its one step over.
The image quality of the sides screens in FC3 were pretty crappy, but the FOV wasnt messed up like that, at least not that bad.
Also, I know with Surround the side screens arent supposed to be the same aspect ratio because of the whole peripheral vision thing. But is there a way to not let it do that? It doesnt make sense really, because they are basically just doubling the peripheral vision effect, once by your actual eyes (how it should be) then again on the monitors.
Havent tried anything else yet, about to go to bed. Is this the norm for Surround, or does anyone know of any fixes for these issues? If this is how it always is, Im rather upset I spent the money on it.
EDIT:
Figured Id give Skyrim a try really quick. Tried Hayden's fix, and its not supported by the current verison.
http://www.wsgf.org/dr/elder-scrolls-v-skyrim/en
Another strike :(
You should probably read this thread on WSGF:
http://www.wsgf.org/forums/viewtopic.php?f=68&t=14082
It explains the "side screen distortion" that you're seeing. Basically what you're seeing is optically correct for the FOV you've chosen and for 3 monitors arranged in a flat plane.
I can't speak to the stuttering issues you're seeing in Far Cry 3 but I have run into the same problem with Skyrim that you have. Every time they update that game it breaks Hayden's fix and he needs to re-do it. Sucks.
Been playing BF3 for a few hours, and that one seems to work well. Just got to get used to focusing purely on the center screen.
Going to try GW2 and some RPGs over the weekend. Might buy Dishonored.
Make sure you run the Flawless Widescreen fix for Dishonored, otherwise it's Vert- and doesn't look right at all.
BF:BC2 also works really well in Surround.
Surround gaming has its issues. I'm running triple 30's in portrait mode and updating my drivers causes all sorts of problems. I experienced the stuttering problem you're having in BF3 and that drove me nuts. I would engage someone up close and stutter and would end up on the ground calling for a medic. Narrowed it down to the driver because I downgraded to another version and it resolved the stuttering problem for me. Give that a try. 295.73 is the highest I can go without having other issues.
