IndyJoe said:Had there ben any information on weather ATI's technology would work on an SLI board? Currently aren't the SLI motherboards the onle ones with two PCI-Xpress x16 slots?
Just curious
Intel_Hydralisk said:The SLI mobo doesn't just have two PCI-E slots. It has special logic that lets it control two cards in tandum... and I'm thinking it's specialized for nVidia... *cough* nVidia nForce4 *cough*... only time will tell though.
The multi-GPU technology ATi is using isn't exactly something 'they've never done before'. It's a somewhat watered down version of one of their commercial technologies, used in flightsimulators and similar VR setups, whereby up to 34 GPUs can work together.J-Mag said:Well if you look at what ATI is doing: designing motherboards for the first time...
Seems obvious to me they are doing this for a reason... To support their Multiple Card format (obviously they are starting simple with one 16x slot solutions, but that is probably because they have never done this before).
IndyJoe said:Hightest, thinks for the info. That was actually my original thought. That the Nforce 4 chip just allowed the two x8 sockets and the card did the rest for SLI.
So it actually sound as though ATI's multi rendering solution potentially could work on an Nforce 4 board. This is all going to be very interesting how it plays out.
J-Mag said:Well obviously ATI isn't betting on this otherwise they wouldn't be making motherboards...
You're right. SorryJ-Mag said:You misinterpreted my post.
Making MOTHERBOARDS is what i was refering to...
I know ATI has has multiple GPU setups for a while...
I was under the assumption that it divided the display into 34 sections, each of which being rendered by a single card. Perhaps this applies only to MVP?mavalpha said:[..] ATI's commercial solutions allow up to 256 VPUs, not 34.
mashie said:We don't know, it is possible ATI MVP will work in nForce4 mobos.
This is from the R300 White Paper right here at [H].http://hardocp.com/article.html?art=MzI3 said:...and a few more conversations with engineers has uncovered the fact that the R300 VPU is capable of being utilized in a multi-VPU configuration with up to 256 R300 VPUs being utilized on a single "card".
...and this is from XBit's CeBIT '05 coverage.XBit Labs said:...Still, the AMR is projected to operate pretty fine on mainboards featuring NVIDIAs nForce 4 SLI, VIAs or Intels chipsets
Requires two physical x16 connectors on the mainboard;
Load balancing and synchronization implemented entirely in software;
No physical connector requires between devices;
Works with any PCIe north bridge.
