Nvidia SATA Drivers keep being redetected when rebooting pc
IceDigger
I just installed the latest nforce drivers on this old nvidia 6150LE motherboard and the oddest thing happens. After every single reboot it redetects the sata drivers and installs them. Every single reboot.
Any ideas?
Oh yea, the pc is running windows xp.
There may be an issue with the newest nforce drivers and such an old board. Have you tried using drivers a bit older?
Download some older ones first (incase you lose your nic driver), then in control panel, remove the nforce drivers and reboot. If it doesn't try to reinstall them again then you're good to start experimenting.
Is this the package you downloaded? (most recent)
Here is one about a year old.
If you have to, try rolling back to this one from a couple years back.
But, just an FYI, in my experience, Nvidia makes poor SATA drivers. When it comes to Nvidia, I just use the GPU drivers. If I have to, because none are provided, I will use Sound/Nic/SMbus drivers. When it comes to controller (ide/sata) I will use the default unless aboslutely necessary (in the case where I'm using XP, in AHCI mode and need the newer controller driver to hide the quick remove icon or if I'm using raid. In Win 7/Vista, drivers are provided).
... yah, what chris said. i used the default xp drivers with my GF6150.
I was just lazy and disabled his sata controllers in the bios as the guy had both an ide hdd and cd drive.
Yah, even then, make sure you're not using the NVIDIA IDE drivers. :p
Haha, yea. No idea why but not just their ide/sata drivers are bad but their network drivers are horrendous.
