- Dec 19, 2005
“Nvidia RTX 6090
NVIDIA’s RTX 6090 will reportedly use NVIDIA’s GR202 silicon, which reportedly features up to 192 Stream Multiprocessor (SM) units. The GPU is also expected to feature a 512-bit memory bus, with the GPU supporting 32GB of memory.Nvidia’s RTX 6090 is unlikely to use all of Nvidia’s GR202 silicon, much like most other RTX XX90-class GPUs. Nvidia’s RTX 5090 features 170 SM units, which means that the RTX 6090 could feature an SM count that’s up to 12.9% higher. Furthermore, Nvidia’s RTX 60 series GPUs will also reportedly feature slightly higher clock speeds than their RTX 50 series GPU models.
If these specifications are correct, Nvidia’s RTX 60 series performance gains will stem from architectural advantages and not raw increases in SM count. If Nvidia intends to deliver a 2x increase in path tracing performance, we can expect some big changes to how ray tracing is handled with RTX 60 series GPUs.”
Source: https://overclock3d.net/news/gpu-displays/alleged-nvidia-rtx-60-series-gpu-specifications-leak/
