NVIDIA Roadmap Outline for 1H08
So the G100 aka 10,800GTX will be out in Summer too ?? So why even make this "9800GTX" that is no faster than an 8800Ultra and then will be replaced in a few short months by the 10,800GTX ??
Because rather apparently, there is a demand for it. And, hell, a lot of people thought G100's were coming sooner and took a risk w/eVGA's step-up- not the smartest risk in the world, but the fact stands that a lot of people seem to have. Between those people, anyone looking for a very high-end rig around now, and people who just like having the latest tech in their rigs, the 9800 series will have an appeal. Plus, it ultimately seems to basically be a continuation of their G92 line of products which has done well for them so far- better, more efficient performance for a lower price (granted, so far that has also meant smaller memory buses, but I somehow doubt the 9800GTX will feature such a flaw.
Btw, can we make a rule about if you don't have anything you haven't said 1,000 times before, don't say it? Or is there one already? Because this and similar threads have been locked on basically replies and counters to a single post which has been spammed infinitely and only slightly modified (but to no actual impact on the conversation) each time.
So what is the release date of the R700, I would think like July time, that would be 6months after the 3870x2 from official release tomorrow ??
Both R700 and G100 should be arriving late Q2/2008.
Why would they do 9800 GTX and GT? I have said it few times now already.. to maintain their profit margins. 9800 GTX will be much cheaper to make than 8800 GTX/Ultra and it won't be far in performance. If you would look at performance/$-ratio this kind of 9800 GTX would own 8800 ultra in this.
Look this way:
Geforce 9800 GX2 vs. HD3870 X2
Geforce 9800 GTX vs. ?
Geforce 9800 GT vs. HD3870
9800 GT won't be big upgrade from 8800 GT, but that's enough to give Nvidia's this price segment big enough boost. 9800 GTX would take 8800 GTS 512's place and since 9800 GTX will be better -> it will sell lot more.
Right now Nvidia is just answering to AMD. When AMD releases RV770, Nvidia releases G100. This cycle ends only when AMD releases clearly better card (Remember Geforce FX vs. Radeon 9xxx? This resulted to that Nvidia rushed Geforce 6 out fast which was hugely better than FX-series (6600 GT owning any card from FX-series)
my speculation:
GF 9800 GT and 8800 GT differencies
Core: +50MHz
Shaders: +125MHz
Memory: +150MHz (62.4GB/s vs. 57.6GB/s)
Power consumption: +0W (with new G92 revision)
GF 9800 GTX and 8800 GTS 512 differencies
Core: +100MHz
Shaders: +250Mhz
Memory: +260MHz (with GDDR4 (73,6GB/s vs. 62.08GB/s))
Powerconsumption: +10W
Vram amount: +512MB (making it 1024MB)
It would have 15.4% higher core clock and 18,5% higher memory clocks. In this case it would win 8800 GTX in lower resolutions and in higher resolutions it would be tight.. in 1920x1200 level 9800 GTX would still have and edge and this resolution is highest that you are supposed to play with single that price level card. 8800 GTS 512MB doesn't lose to 88 GTX in higher resolutions just because it has smaller mem bandwith, but also because it has smaller amount of vram. I mean that for example Unreal Tournament 3 at 1680x1050 with very good settings, AA/AF enabled, uses very often more than 512MB vram (I have 8800 GTS 640MB)..
And release 9800 GTX with 8800 GTS 512MB price tag(perhaps +$50..depending on what will be HD3870 X2 prices + 9800 GT with 8800 GT price tag. Since AMD doesn't have anything new for this performance-price class.. These cards should sell better than their previous versions. Unless AMD comes up with another price cuts.
You're still making the assumption that the 9800 GTX won't be a significant upgrade, over the 8800 GTX, which I disagree.
This would mean the 9800GTX is a weaker overclocker than the 8800GTS(92).
Not only that. It would also mean that the new 9800 GTX, is in fact slower than the 8800 GTX/Ultra @ higher resolutions, which doesn't make any sense.
Look this way:
my speculation:
Core: +50MHz
Shaders: +125MHz
Core: +100MHz
Shaders: +250Mhz
First of all, that makes no sense. NVIDIA does not need to release anything to compete with the HD 3870. They already have better cards: 8800 GTX, 8800 Ultra, 8800 GTS 512 and the 8800 GT.
Second, you used an example that doesn't apply today. The 8800s, which use a G80 chip, or one derivative of it (G92), were and still are extremely successful and they have a lot of mileage left in them. If you read reviews of G80's architecture, you'll find that's it's very flexible and expansible in many ways (like the memory bus).
NVIDIA had to come out with the 6 series faster, because the FX line sucked. That does not apply today and using a derivative or improved version of a successful chip, usually provides predictable performance results overall. A clear example of that, is the 6 series to 7 series transition.
I find it very unlikely, as I already mentioned in this thread, that the 9800 GTX is just an overclocked 8800 GTS 512, as you seem to point out. Having 1 GB of VRAM will NOT make a significant difference, over the existing 8800 GTS 512. The Stream Processor frequency will help, but again, nothing major over the existing GTS 512 and @ higher resolutions, it may be close, but this new card would still lose against a 8800 GTX or Ultra and that makes no sense at all.
Why wouldn't? I mean G92's 256-bit bus is kinda slowing it down anyway..8800 GTS 512MB already uses the maximum amount of processing units that G92 has and has this 256-bit bus so only way for 9800 GTX to be fast is to have huge clock frequencies.
That won't make a big difference. Higher clocks lets you achieve better performance no doubt, but nothing major. It won't make up for the not so wide memory path, which is very important, as you go up in resolution and use AA.
G92 uses a 256 bit memory bus in its first incarnations, because it's cheaper to produce that way, which means the card will cost less in retail. You didn't get a 8800 GT for $250 because NVIDIA is kind, but because they engineered the chip this way, to reduce their own costs. Keyword here is "first incarnations". Don't think that because you only saw G92 using a 256 bit memory interface, that it is limited to it. Same thing applies to the number of Stream Processors. The improved version of the chip in the 9800 GTX, will not be the same as the chip in 8800 GTs and 8800 GTSs 512.
It would be weird if they would name that remarkably new chip as G92. I mean we know that G92 has now 128SP and only 256-bit bus and adding more SP's and bringing wider bus would mean major update for G92.
This far, we only know that GX2 will use G92. I'm still waiting for the link that factually shows that the chip powering the 9800 GTX, will be exactly the same as G92 and thus, have the same codename.
And it wouldn't be that major, since G80 supports it (at least the wider memory path) and there was a mysterious part of G80, which was not being used and some even speculated, that it could be an additional set of Stream Processors, included for future upgrades.
Exactly, I game at native 2560x1600rez in every game on my 30" Display. I just have 1-8800GTX and it plays all my games nice with 2xAA/16xAF, I will never buy ScamLI, I mean SLI, why pay another 100% for the second card to only get like 50-75% at best back in benchmarks.
I was hoping a new named product "9800GTX" would just have to be way better than the current 8800GTX, and mainly at high rez of 1920x1200 and 2560x1600, anything lower like 1600x1200 is old school rez now a days.
Whats the point of a next generation named product if it will be worse or slower than the previous generation at high rez, that makes no sense at all.
Let's face it.. G80 is dead. Gone.. Architecture will live on, for now in G92, and also in low/mid end chips like G94/G96.
But G80 will be gone in a few weeks. All except GTX/Ultra are alredy EOL, and Ultra is not being produced anymore in any significant numbers, since all the manufacturers are preparing for next top card(s). So we're left with 8800GTX.
But nVidia WON'T keep production of G80 just to supply card manufacturers just for 8800GTX, and it WON'T produce new chips just to power up new 9800GTX.
So it's almost 100% sure that (even from economic view only) nVidia's new 9800GTX will be G92 card. Tweaked to the max (just like G80 was in Ultra), but it will still be G92.
That will cover whole top part of the game with G92, and low/mid with cut down chips in the form of G94/G96. And it will stay that way till G100(or G200, whatever the name) comes out.
Just to quote one news: "Nvidia has informed its partners that it won't be accepting more orders for Geforce 8800 Ultra and advised everyone to try to sell them as soon as they can." That's as of NOW. Actually, it's past already :)
You missed my point and you seem to take everything literally.
G92 is a derivative of G80 and thus, inherited the same flexibility and expansibility. Just because you only saw G92 versions with 256 bit memory paths, don't think that it's limited to it. It makes even less sense to believe that the new 9800 GTX will be similar to an overclocked 8800 GTS 512...
If anything, the supplied nVidia quote suggests that the 9800GTX will have a memory bus greater than 256mb. Why? With only a 256mb bus, there would still be a demand for 8800 Ultras for those who want/need/require a larger memory bus. However, with nVidia flat-out saying they are not accepting new orders for 8800 Ultras, they are also saying that they foresee no demand for 8800 Ultra's with the launch of the 9800GX2 and 9800GTX- meaning they fully expect to exceed the performance of the 8800 Ultra with their new cards at an equivalent or lower price (current price- not launch price).
True and false. Yes, new cards will be faster, and Ultra will be obsolete in a few weeks. But no, it doesn't say anything about 9800GTX, since GX2 is the one that wil obsolete Ultra, and not GTX.
Right, but it indirectly speaks of the 9800GTX because I think even nVidia realizes the present stigma against GX2 solutions- thus, even if the GX2 soundly thwacked the 8800 Ultra for a smaller price nVidia might still see at least moderate demand for the 8800 Ultra.
I do not think Nvidia has anything to gain by holding back the release of the G100. Whether G100 is the 9800GTX or some other future card, Nvidia stands to make the most amount of money by releasing G100 as soon as it is ready. It is difficult to justify the purchase of the 8800GTX or 8800 Ultra now given the performance and price of the 8800GT and 8800GTS 512, so the ultra high end is sort of stagnant now. The 9800GX2 will likely be in the $450 - $500 range in order to spoil ATI's 3870 X2, so tumbleweeds are blowing through the $600+ market segment for the most part. If the G100 is released as the new ultra high end and is unopposed in the market, Nvidia can charge a premium price, many enthusaists will buy it, and they will enjoy higher margins for a longer time. If they wait and release G100 in response to RV770, they run the risk of having to price G100 lower in order to compete (depending on the performance of the RV770, of course).
I completely agree with Silus, and I feel that if NVidia has the immediate capability of releasing a single chip solution that significantly outperforms the 8800GTX/Ultra, they will do so as soon as they can (hopefully as the 9800GTX). I think G92 may be able to do the job if it is pushed to its limits. SOMETHING needs to go in the $600+ price segment soon... :)
I would disagree they have no reason to introduce the G100 at this time. A further revision of the G92 maybe 8x64 = 512 stream processory version. Maybe it will be called G90, but whatever with it being 55nm/65nm it should have higher clocks and with more power we can see something that is still based on the G80, but offers 50% boost in fps.
Remember regardless they are the top dog even with a revised G92 GTX version nothing can touch it... so they wait and perfect and tweak the G100 and ensure that we have a 100% or greater performance boost!
I really don't see them bringing out the big gun until ATI brings something to the table. Period.
Although I'd love to see a new highend card like the 9800 GTX I'm afraid this won't happen.
The 9800 GX2 will be Nvidias new highend card. If they had a powerful 9800 GTX they wouldn't have to release a GX2 card.
Because ATI wants to deliver the R700 in the end of Q2 Nvidia will deliver too - the GT200/G100.
So why should they release a new GTX highend card 2 months after the GX2 and two months before the GT200/G100?
The only thing which might happen is a G92 refresh of the GTX (think of a higher clocked GTS) but this card will be disappointing if you expect a highend card.
I'm afraid I agree, and I think if there was 9800GTX coming out any time soon we would have seen pics/specs/rumors etc by now.
But there "is" a 9800 GTX coming out soon. As for Specs/Pics, G80 was a mystery up until 1-2 weeks before it was released, so this is nothing new. And rumors, well, they are already out, including the 55 nm, 384 Stream Processors with a 512 bit memory path and 1 GB of VRAM, which is too much IMO.
Still, the 9800 GTX will NOT be basically an overclocked 8800 GTS 512.
So how do you know it is coming out soon?
I gotcha, but that's ONE place. All the rumor sites would be going nuts with it if it was a reality. But hopefully you're right. I want to upgrade like now and I don't want to do quad SLI. A G92 GTX would be ideal for me.
xp3nd4bl3, don't bother... Pretty much it seems Silus is only one convinced 100% that 9800GTX will be an uber-card that will crush all old nVidia cards, together with anything ATi can throw at it :) Be patient, all of you, Feb is right around the corner ;) Though I'm affraid we won't hear any real good news :rolleyes:
Oh, and forgot to say it earlier to you Silus, as much as I remember - G80 was rumored A LOT even quite some time before it came out. When was it out? November 2006? So if news about it were out only 1-2 weeks before, how come I just found this one after 5 minutes of googling?
http://www.vr-zone.com/?i=4007 - close to 700mil transistors (was true), core clock up to 1.5GHz (was pretty correct, keeping in mind it's actually clock of stream processors inside core, but people didn't know it back than), 128 stream processors (true again), 384bit memory interface (again...), 768MB memory size (true), names to be 8800GTX and 8800GT (almost, it was GTX and GTS), unified shader (true). Did I say this was posted on September 19th? Also, INQ posted some stories even earlier.. here. Note the link to July '06 story about tape-out.. Now that's not 1-2 weeks before, right? It's pretty much info and much before November 8th when 8800GTX/GTS went out officialy.
Cya!
Cya!
Well, while trying to prove your point, you proved mine. Well done! Thanks! You just showed me a rumor, which, yes, contained some info that turned out to be true (that happens all the time), BUT the real specs were only known i.e. confirmed, 1-2 weeks prior to the release of both the 8800 GTX and 8800 GTS.
And I didn't say it will be an "uber" card. Please don't say I said something I didn't...
I believe that the 9800 GTX won't be the "overclocked 8800 GTS 512" as some of you seem to think it will be. I speculated, based on G80's architecture, that the 9800 GTX may be a jump in performance from the 8800 GTX, similar to the jump of the 6800 Ultra to 7800 GTX i.e. 60-70% faster. Or "at least" 30-40% faster. That's not "uber", since most wanted "at least" a 2 x faster card than the current 8800 GTX.
To believe that the 9800 GTX is basically just an overclocked 8800 GTS 512, doesn't make sense to me.
Yes, it's ONE place, but it's NOT a rumor site. What [H] presented was NVIDIA's roadmap for the first quarter. No specs or pics are shown, because they were not given. When [H] knows more, so shall we.
I hope you understand that rumor sites IE the INQ and fudzilla make shit up to generate traffic for their ads, and really dont give a shit if its true or not...its there predictions, nothing more, nothing less. They arent going nuts because they dont actually know a goddamn thing, but simply guessing at best.
I would believe [H]/Kyle before anyone else. If Kyle says its happening, its a safe bet its happening the way he says it. I didnt pay attention to his posts awhile back, and he turned out to be right anyway, so for now, i have some pretty good faith in Kyle. Although if my faith is misplaced, at least ill get to see him in a tutu.
I havent read much of this thread, but if i had to guess id say the 9800 GTX will have 192 shaders, and perhaps a 384 bit memory interface, with 768 of ram again. Core clocks i would expect to be in the 725-750 area. I dont see any reason for nVidia to go to a 512 bit/1gb of ram design. The 384 bit doesnt really do anything significant unless your at 1920x1200 and above.
Thats the whole point in a VideoCard like the GTX, I only play at 2560x1600rez, and most people that have or will have a GTX are Gamers that have at least 1920x1200rez basic low rez or the 30" Display
The way things are ultimately breaking down, if the 9800GTX sports a 384-bit bus, it will undoubtedly be the option for those looking to run at higher resolutions, and it certainly will support triple SLI and the like, given that it will probably be meant for SLI. On the other hand, despite the 9800GX2 replacing the 8800 Ultra from the standpoint of single card performance, it will likely be geared more towards those looking for good single card performance at resolutions a streamlined ([H] has noted that the G92 seems to be using some form of new, better compression) 256-bit bus can handle.
If Nvidia would have something like a G90 (for the 9800 GTX) why should they release the 9800 GX2? They have to produce two PCBs for the GX2, it costs them much more than building a single card.
Maybe Nvidia had the G90 but it failed? Due to ATIs weak performance it wasn't a real problem; they were able to publish their mainstream/performance G9X chip (G92) and use the G100 for their next enthusiast card. Just look at the temperatures and power consumption of the G92. Think about how much more a G90 would produce/require.
This would also explain why Nvidia first wanted to use the G92 to refresh the 8800 product line - because they didn't have a real new enthusiast card.
If a combined 8800 GTS SLI (9800 GX2) is the best Nvidia can offer, I don't expect a GTX to follow. The performance would be disappointing.
Nvidia has failed at nothing.I think Kyle is right,in that Nvidia is biding thier time,and have a siingle chip solution ready to go,that will trample the G80/G92 series,but given they have little to no real competition,they are sandbagging,and only doing what they have to,and
nothing more.
I also think the GX2/3870 X2 and 9800GTX will be fairly short lived products,and that by the late Summer early Fall,we will have single chip (55HS nm based,1+ billion transistor) high end cards that will impress most of us from both camps.
Probably, but for once I'll embrace a short-lived product (Step-Up will make you do crazy things).
I agree, i was just mentioning that there isnt really any reason to move up to a larger bus when the 384 bus doesnt really even help until the higher resolutions anyway, IE, i think 512 would be complete over kill, but for all we know the G92 core could have a few tricks up it sleeve and may even be able to take advantage of an even larger bus. Time will tell.
Silus (and others), if you believe Kyle's words 100%, than why do you keep arguing (and hoping)?!
Quote from the same article:
GeForce 8800 Ultra will be replaced by the GeForce 9800 GX2
The GeForce 8800 GTX will be replaced by the GeForce 9800 GTX
Now aditional facts:
Ultra = faster than GTX
"The 9800 GX2 is said to be at least 30% faster than a 8800 Ultra." (from other HOCP article; linked in article linked above)
Ok, now, "at least 30%" won't mean that it's 80% in some games. That would be just dumb to hope..
And now you just have to combine it all, meaning that 9800GTX, which IS REPLACING SLOWER CARD THAN GX2 IS REPLACING, can be .. let's say "at least 15%" faster, meaning, it won't be "at least 30-40% faster" or "60-70% faster" like you suggest. If it was, than Kyle would have written that Ultra is being replaced by GTX and GTX with GX2, right?
Kyle's article didn't say "GX2 will be faster in quad-sli than GTX in tri-sli or dual-sli, but GTX will be faster on-on-one" or whatever, so that's your guess, and I won't go into that since SLI is quite variable and goes from negative performance to ~0,7-0,8x increase (per chip) if optimized well.
Taking Kyle's words and roadmaps as facts means that 9800GTX WILL NOT BE 70% faster or even "at least 30-40% faster". It would be logical to say 10-15% faster AT BEST, but I'll leave it to you to hope that it will be 15% at LEAST, and let's say 20-25% at best (giving you more room here than logicaly expected).
I admit I've made same "selective reading at start" but you keep it up even after 15 pages :p
Like Kyle said, "Some will laugh, some will cry, and some will wonder “WTF?”"... So take off those pinky glasses, face the grim grey world, and start asking "WTF".. :D ;)
NHF man, I'm just trying to wake you up so you don't get a heart attack when real news with complete specs start comming in in a few weeks :D
So what this means is that there will be a "9800GTX" but per Kyle the 9800GX2 will be the 8800Ultra killer, so the "9800GTX" won't even beat the year old 8800Ultra if I am understanding this correct ??
That is the dumbest thing I have read in years, why the fuck would nVidia create a brand new generation named product named "9800GTX" and it won't even beat the product with 2006 year technology the 8800Ultra, so this new 9800GTX will only be like 5-10% faster than the current 8800GTX, that is crazy to even make it then, we already have the 8800Ultra itself which will be faster than this 9800GTX ??
To wait all this time from November 2006 for the first 8800GTX series to all the way until Spring 2008 for the next generation named 9800GTX series and the best they can do is not even beat the 8800Ultra or be more than 10% faster :rolleyes:
STFU.
The 8800 Ultra was 10% better than the 8800GTX. The 8800GX2 is 30-50% better than the 8800 Ultra. That leaves a 0-30% gap (at least) for the 9800GTX- and anything above 0% is better than the 8800 Ultra. Learn to f-ing read bro.
Nah, I ment 15% faster than ultra could be achievable by new 9800GTX. Meaning some 25% faster than current 8800GTX. But I wouldn't push it any further.. :(
P.s: Couldn't make a proper quote, sorry ppl, something's up with forum..or my computer :p
Probably the forums- they're acting like posts are new for me when I've already read them three times.
