nvidia overclock utility.
Filter
taling with my friend. what softwared utility can you use to o/c an nvidia card.
like i use rage3d tweak
Alot of people use Coolbits which is a file that you just double click on and it adds a string to the registry that unlocks the ability to overclock in the nVidia driver properties but i didn't like it all that much because it s picky about how far it will let you overclock.
Most people use Rivatuner. I like it alot. And here is a guide on how to overclock using RivaTuner.
http://www.andrew.cmu.edu/user/fma/overclocking__graphics_card.htm
riva tuner was what i was looking for thanks i couldnt remeber what it was been so long since i've used an nvidia card.
