Nvidia "optimal clock" speed test?
Weenis
I said WEENIS, not...
Hey guys I'm running the system that's in my signature and I wanted to know if I could safely oc my video card a little.. nothing major just find the optimal speed it can handle on stock cooling.. what bugs me though is.. I go into the nvidia control panel and try it with their program.. it goes to a white screen and does nothing? Any ideas. is it supposed to do this, or is this a problem ? (I'm downloading the new 158s right now.. maybe that will clear something up.
You should have no problem overclocking just a little, if that is what you really want. nTune should do. Just do it in baby steps, 5-10Mhz oc at a time (the right way). In my case. i went all the way first (bad), but couldn't be bothered with baby steps.
The "Detect optimal speeds" routine has been broken for some time now, especially if you're using Windows Vista.
Overclock it yourself, I would recommend using a third party tool like ATITool. The artifact checking routine in ATITool is quite nice.
thanks guys.. I have XP pro, still haven't made the vista plunge yet.. 64bit has to much of a lack of support and programs etc.
I'm happy to inform you though that the 158 drivers that were recently released, do fix that issue.
