nVidia - No more dummy plugs?
If its the Registry edit, it only works some of the time for me
Plus when you have a bunch of GPUs its hard to tell where to make edits.
For me Id rather just use dummy plugs
I've been out of the loop for a while, but what ever happened to the ability to force detection of displays? I used to be able to check a box to force a video card to think a display was attached.
Unable to access the post/article:
Forums.slizone.com and forums.nvidia.com are currently down while we work to merge the two forums together. We anticipate that the forums will be back up on 10/30/2009. We apologize for any inconvenience this may have caused.
Based on reading that mess, I'll stick with dummy plugs as well if I ever needed to run Vista. :D
Promising tho. I used to use that HDTV thing that comes with cards and force it to display, worked for me
Posted via [H] Mobile Device
