nVidia nForce MediaShield 15.23, .25, .26 - Does Not Install!
JakFrost
Cross-post: NVIDIA Forums > nZone > Hardware > nForce Mobos > nVidia nForce MediaShield 15.23, .25, .26 - Does Not Install!, MediaShield installer does not install services, GUI, or files.
The Problem
I have the an nVidia nForce 4 AMD SLI based motherboard and I have been using the nForce 6.86 storage drivers for a very long time. Before this problem I had my system with 2 x 320GB nVidia RAID MIRROR for OS C: and D: drives, and 2 x 500GB nVidia RAID MIRROR for E: drive. All four SATA ports on my motherboard were set to RAID and MediaShield 6.86 worked fine showing all the drives.
Intel SSD + nVidia MediaShield 6.86 = OS Start Freeze!
I have just purchased the Intel X25-M 80GB MLC SSD drive and decided to re-install Windows XP SP3 cleanly on this drive. This is because I need to do a partition alignment and the only way to do it at this time is to pre-create the partition with "diskpar.exe" utility from Microsoft and set the sector offset to 2048 sectors (512-bytes per sector) or 1 MB into the disk to ensure that the new partition starts at a 4KB SSD page boundary and also at a 1MB boundary that will be evenly divided by various SSD erase blocks (128KB, 256KB, 512MB) and RAID stripe sizes (64KB, 128KB, 256KB) so they will all fall on the that 1MB boundary. I read that Windows Vista and 7 do their partition creation on sector 2048 so I'm following suit with this Windows XP install also on this SSD.
I first tried to test the SSD by doing a clone copy of my OS from the HDD using Acronis Disk Manager v10 but the SSD won't boot the OS all the way. I did a clean OS installation on a the new SSD and then installed the old MediaShield 6.86 storage driver but it still will not boot up and gets stuck loading a driver after MUP.sys according to Safe Mode, same as with the image.
New OS Install + nVidia nForce 15.23, .25, .26 Drivers = No MediaShield GUI!
Now I'm trying to do new OS install on the SSD without RAID for C: drive connected to SATA Port 4 - RAID = Disabled. Also I have 2 x 500GB set in a nVidia RAID MIRROR for D: drive SATA Ports 1, 2 - RAID = Enabled for storage and another 1 x 500 GB E: drive on SATA Port 3 - RAID = Disabled.
After the problems with 6.86 I noticed that a new nForce 15.23 release because available for my motherboard and downloaded this one. However, when I install it in my OS the MediaShield GUI does not get created and the NvRaidService*.dll files do not get copied to "%SystemRoot%\system32\" folder. I downloaded the newer 15.25 and 15.26 releases and they do not install MediaShield either, even though all the other drivers install, including the newer storage drivers 10.3.0.46.
I've tried changing my BIOS to make all SATA ports as RAID = Enabled but still could not get MediaShield to install. I tried adding the SSD to a new Stripped array by itself and installing the OS on it but MediaShield won't install. I changed the drive from SATA Port 1 and Port 4 but it doesn't matter. MediaShield won't install.
nVidia nForce 15.23, .25, .26 Drivers - \IDE\WinXP\raidtool = raidtool.cab + Missing Installation INF!!!
I extracted the installation package and looked into the "\IDE\WinXP\raidtool" folder where MediaShield is supposed to be and I only find a compressed "raidtool.cab". When I extract that I find all the required files "NvRaidServer*.dll nvraidservice.exe NvRaidSv*.dll NvRaidWizard*.dll NvSataConnection.exe NvSataConnection*.dll nvsto*.chm" including the "RegRaidSedona.bat" utility but this CAB file does not get installed. It contains the "default.inf" file but this file does not install properly from this cab. It contains the "DestDir=11" = "Copy To %SystemRoot%\system32" folder instructions for certain files but they don't get implemented since this .inf is never called.
The "RegRaidSedona.bat" is more interesting since it assumes that the "default.inf" was called and it copies the *.dll files to the proper folders and tries to register the "nvraid*.dll" files and then start MediaShield "nvraidservice.exe" but it doesn't work fully. When I try to manually copy the files and run this batch file I get a partial result. The new NVIDIA Control gets the "(+) Storage" group with three pages of information but all the pages have blank tables in them and do not display any drives in the system. My guess is because "nvraidservice.exe" is failing to do what it is supposed to do.
Also there is no more "NvRaidMan.exe" GUI file in the "raidtool.cab" even though the new "nvraidservice.exe" still references it internally.
What To Do Next?!
I had problems previously with the old 6.86 version the same way trying to get it installed with the GUI and I finally did it but that was years ago and I don't remember what magic I did to make it work. Now it's the new 15.xx releases and the same problem is here with a new drive and new OS install. I cannot use the old 6.86 drivers since they freeze my OS with this SSD. What do I do next?
Either way, if it's something that I'm doing or not I should be able to force the MediaShield GUI to install properly whether I'm using RAID or not because there's always a chance that I'll switch to RAID for other drives in the system later.
[size=-2]
CPU: AMD Opteron 175 Dual-Core 2.2 GHz 1 MB 90 nm 939 11x CCBWE 0543TPMW VID 1.350 V - 2,475 MHz (225x11x4), 1.55 V (1.55 V x 104.8 %)
FAN: Zalman CNPS9500 LED 92 mm Fan+Heatsink + Arctic Silver 5 Thermal Paste 99.9 % - 35 C Idle, 45 C Load
MOB: DFI LanParty UT SLI-DR Expert 939 nF4 PCI-e Rev.AA0 - BIOS: 2006-04-06 Modded, LDT 1.20 V, Chipset 1.52 V, 42 C Load
RAM: Mushkin 1 GB XP4000 Redline 991493 DDR500 3-3-2-8 2.6-2.9 V CE-6 - (4) DIMMs, 225 MHz (1:1) 2T 3-3-2-8, 2.80 V
VID: eVGA nVidia GTX 260 896 MB G92 192c 576/999 MHz PCI-e 2.0 16x 2xDVI 1xSVid 1xHDTV - 600/1100 MHz, DVI to LCD, HDMI 60' to 50" Plasma TV.
SAT: Silicon Image 3114 PCI SATA-I 150 MB/s RAID 0,1,5 Onboard Controller FW: 5.3.14 Modded, Only for eSATA since PCI bus problems with Sound Blaster X-Fi
HDD: Western Digital Caviar SE16 500 GB WD5000AAKS 16 MB SATA-II - (2) in (2) 465 GB nVidia RAID1 (Mirror) Arrays
HDD: Western Digital Caviar GP Green 1 TB WD10EACS 16 MB SATA-II - (2) external Movies, (2) external for Backups
ENC: MacAlly G-S350SU External HDD Enclosure 3.5" eSATA USB 2.0 Aluminum, Universal 12V Adapter - (2) external WD GP 1TB for Movies
ENC: i-Rocks 9410 External HDD Enclosure 3.5" eSATA USB 2.0 Aluminum, Univeral 12V Adapter - (2) external WD GP 1TB for Backups
NIC: nVidia nForce4 Gigabit Onboard PCI NIC
NIC: Marvell Yukon 88E8001 Gigabit Onboard PCI NIC
SOU: Creative Labs Sound Blaster X-Fi Xtreme Music 24-bit 128-Voice 109dB SNR - EAX 4.0 for games and music.
SOU: RealTek ALC850 AC'97 Rev 2.3 8-Channel Onboard Audio - S/PDIF out to vid card for HDMI Audio for TV.
BLU: LG GGW-H20L Blu-ray 6x BD-RE 16x DVD SL/DL 48x CDR SATA - FW: YL05
DVD: NEC ND-3550A 16x DVD+-RW SL/DL 48X CDR PATA - FW: 1.07
POW: OCZ PowerStream 520W SLI ADJ ATX2.0 EPS12, +3.3V 28A +5V 40A +12V 33A
CAS: Lian-Li PC-V1200 Plus Mid-ATX Aluminum 4x5.25 6x3.5 2x120mm - Best case to date in my opinion.
MON: HP LP2475w 24-inch LCD H-IPS Monitor Wide Gamut 102% NTSC 6-12ms Response - 1920x1200x32 60Hz, DVI, GIG122/GIG052, Bri 15, Con 80, 9300K
ROU: Linksys BEFSR81 EtherFast Cable/DSL Router 8-port Switch 100MBps FW: 2.51.3
JOY: CH Products Fighterstick USB 3 axes 24 buttons
THR: CH Products Pro Throttle USB 3 axes 24 buttons
PED: CH Products Pro Pedals USB 3 axes
KBD: Microsoft Natural Keyboard Pro USB/PS2 Media Keys
MOU: Microsoft IntelliMouse Explorer 1.0 Optical USB/PS2 Scroll-Wheel 5-Button
[/size]
Wrong Driver Loaded During TextSetup
I decided to do another OS install today but this time with all the drives connected. I had a NVIDIA MIRROR array made up of two drives setup in the RAID BIOS during boot and my system drive and another drive setup without RAID support.
I realized something today when I was doing another OS install during the blue screen Text Setup that asks you to select the partition to install to. The driver that was loaded was "nvgts" the NVIDIA SATA Driver and the list of disks that was showing tho select the partition to install seemed wrong. It showed four drives to select from instead of three that it was supposed to show, since the mirror array from two separate drives is supposed to be shown as a single logical drive selection since the RAID BIOS is supposed to mask the physical disks. This was not the case but I left the install complete anyway to see what happens in the OS later.
Device Manager - Show Devices by Connection
I later got the idea to check Device Manager and select the Devices by Connection option to see where the disk drives are connected to. Just as I guessed from the problem in the blue screen Text Setup mode all the disk drives were connected to the "NVIDIA nForce4 Serial ATA Controller" instead of the "NVIDIA nForce(tm) RAID Class Controller" as they are on my old OS install that has the old 6.86 drivers installed.
Device Manager - Devices by Connection - NVIDIA nForce(tm) RAID Class Controller (Disks Connected To Correct Controller)
Device Manager - Devices by Connection - NVIDIA nForce4 Serial ATA Controller (Disks Connected To Wrong Controller)
Recollection of Memories - F6 Storage Driver Installation + Floppy Disk + NVIDIA RAID TextMode drivers
After seeing these issues with the disks being connected by the wrong driver I recalled having to actually create a floppy disk to install the nVidia RAID Text Mode drivers since the nLite device driver installation did not work.
nLite + nVidia RAID Drivers in Text Mode
I'm using nLite to do this Windows XP installation by slipstreaming Service Pack 3 into the I386 folder, and also inserting all the hotfixes after the release including Windows Media Player 11, IE7, and IE8 manual install.
Previously I did not take advantage of nLite's ability to add Device Drivers to the installation CD but for this OS install for the SSD I thought why not use it and save myself the trouble of installing the drivers manually. I added the nVidia RAID Text Mode drivers in nLite and it correctly prompted me to select if the driver should be a normal PNP driver or Text Mode driver, and I selected Text Mode. nLite shows two entries for the TextMode driver when you give it the location of the driver folder, the "NVIDIA nForce Storage Controller (required)" and "NVIDIA RAID Driver (required)".
I have a feeling that nLite might be messing up the driver insertion and not letting the RAID Driver load properly so I'm going to do another OS install but this time without the drivers in the installation CD and instead by doing the F6 storage driver installation and using the floppy disk with the drivers.
This sounds similar to what I had to do long time ago to get my own old 6.86 drivers to load properly for this OS install. Wish me luck.
nVidia nForce 15.23 and 25 - RAID Drivers Don't Work
I just tried the nVidia RAID drivers from the newest 15.25 release for nForce4-9 chipsets and no matter what I try nothing works. I tried adding them to nLite image, using F6 with floppy disk, nothing. The newer 15.26 release also has the old 181.xx display drivers but otherwise has all the same driver versions as the 15.25.
I decided to try this installation with the 15.25 drivers because the revision difference for the storage drivers is so small with .42 and .46 driver versions.
Code:
[B]Nvidia nForce Chipset Drivers AMD 15.25 (XP)[/B]
Ethernet Driver (v67.89) WHQL
Network Management Tools (v67.[U]96[/U]) "Sedona"
SATAIDE Driver (v10.3.0.[U]46[/U])  WHQL
SATARAID Driver (v10.3.0.[U]46[/U]) WHQL
RAIDTOOL Application (v10.3.0.[U]46[/U])
SMU Driver (v1.61) WHQL
SMBus Driver (v4.69) WHQL
Away Mode Driver (v6.0.6000.107) WHQL
Installer (v6.[U]69[/U])
The nVidia driver website lists the 15.23 as the last version of drivers to support nVidia nForce 4 chipsets and I tried those drivers also but they don't work either.
Code:
[B]Nvidia nForce Chipset Drivers AMD 15.23 (XP)[/B]
Network Management Tools (v67.[U]93[/U]) "Sedona"
SATAIDE Driver (v10.3.0.[U]42[/U])  WHQL
SATARAID Driver (v10.3.0.[U]42[/U]) WHQL
RAIDTOOL Application (v10.3.0.[U]42[/U])
Installer (v6.[U]14[/U])
The problem is always the same. I have a NVIDIA MIRROR array setup in the ROM BIOS. When I boot Windows XP SP3 into Text Mode setup to choose partitions and I load the nVidia SATARAID drivers .42 or .46 using either floppy F6 Storage Drivers method or slipstream the drivers into the installation CD with nLite, the drives in the NVIDIA MIRROR array always show up as two separate disks and not one single drive, as it is supposed to show up with the 6.86 drivers.
nVidia nForce 6.86 - Intel SSD = Freezes Windows XP Text Mode Setup.
When I tried using the old 6.86 drivers with F6 Storage Drivers option for the Text Mode setup the setup freezes at the point where it says "looking for other installations of Microsoft Windows..." and doesn't move.
Obviously the old nVidia nForce 6.86 drivers do not work with the Intel X25-M SSD. This is the same type of freezing scenario what I found after I tried image my old OS partition from my HDD to the SSD.
Sanity Check - nVidia nForce 6.86 vs nVidia nForce 15.2x
I just did a sanity check to see how the 6.86 drivers react without the SSD plugged in but with the same hard drive configuration as I'm trying to use with the SSD. I just did a Text Mode setup boot and did the F6 driver load for the 6.86 drivers and they work just fine. I see the two drives that are setup without RAID being enumerated by the nvatabus driver and the two drives in the NVIDIA MIRROR array being enumerated by the nvraid driver showing up properly as a single drive.
nVidia nForce Drivers 15.23, .25, .26 = Broken RAID with nForce4 Chipset
The nForce 15.2x drivers are broken and do not recognize any of my arrays from my nForce4 BIOS. All the disk drives are being enumerated by the nvgts driver and none by the nvrd32 driver.
This happens no matter what I do in the BIOS to enable or disable RAID on any of the SATA channels. The problems are not nLite driver slipstream related since I used F6 and a floppy disk with the drivers to test.
