Nvidia Nforce 4 Ultra NIC/ethernet problems - please help!
vsrdan
I have a Nvidia nforce 4 ultra motherboard (this one) with on-board gigabit ethernet. Once in a while the computer says network cable unplugged although it is plugged and the connection is working (I know this is not a connection problem because the computer is connected to a router and other computer connected to it works fine when this happens). So far, this happened 2 times - today and 2 weeks ago. I tried reinstalling drivers (now I have latest drivers), and checking connections, etc., but nothing works. Only when I shutdown the computer (for 3-5min) and restart it, the problem is solved. Just restarting wouldn't work. Can this be a heating issue? Temperatures -as BIOS reads- are: CPU - 30C (max) and board - 35-37C (max). Chipset fan RPM varies from 6500 to 7100 something. Should I try changing chipset heatsink/fan?
The system is:
Athlon 64 3200+ Venice & stock heatsink/fan
Foxconn NF4UK8AA-8EKRS motherboard
PQI Ultra DDR400 (512 x 2)
Coolmax 450W PSU
Hitachi 160GB SATA-II HDD
Powercolor X300 128MB PCI Ex video
Cooler Master Cavelier case with front and rear fans
Thanks for any advise!
