Nvidia LinkBoost removed from all 6xx mobo's
I think it was overheating stuff accidentally. You can still manually raise the voltage or whatever it was doing yourself in the bios if you want.
I haven't read anything about it but...
With linkboost on, the nvidia monitoring software that came with my board reports that the memory clocks on the gpu run at 1330 (stock is 700 i believe), but the nvidia control panel reports that it's running at stock. I had stability issues tabbing between Eve online and any form of video (tv tuner, dvds, or avi/mpeg files). The RAM on the card also ran excessively hot (the RAM sinks would pretty much burn your finger). I disabled linkboost and the video issue went away and the RAM doesn't run nearly as hot. The odd part is that my games/3dmark still ran 100% stable.
