Nvidia- how to uninstall drivers?
socK
Over some time i've installed quite a few sets of drivers. This can cause some preformance problems after a while right? Probualy the dumbest question asked but, how do you unistall them so you can put on new ones? Plus it would work like this, right?
1) Uninstall
2) Reboot
3) Drivers would be back at windows default?
4) Install new ones
5) Reboot and go
Thanks.
You can use a program called DriverCleaner 2 to delete the old drivers, then you would restart, and then install the new ones.
