friend'scatdied
- Feb 20, 2005
Would the 5750 be the equivalent of the 220, the 260, or something in-between?
When was it released?
In-between performance-wise. In terms of feature set I'd put it above either (onboard HDMI with high-quality audio output, Eyefinity, probably more). The 5750 is about on-par with the GTS 250 for 3D performance. It was released 10/13/2009.
The HD 5770 performs about on-par with the GTX 260 216 when overclocked slightly in 3D (a small bit below at stock), and runs much cooler, draws much less power, and has a much more modern featureset. But the 5750 is more than enough for anything you want to do, and then some.
ASUS makes some really nice 57x0s..
