I just switched from an AMD 6670 to Nvidia 550 GTX to finally solve my 23Hz woes. But after attempting to save a 23Hz setting with timing of 23.976 it is not working. So here we go!
In the Nvidia control panel under resolution it lists under SD/HD, for 1920x1080 it has the following refresh rates:
60Hz
59Hz
24Hz
23Hz
When I click to add a custom resolution I choose 23Hz, then under timing set it to 23.976...after the TEST I click save. When it saves it does not save as 23Hz but as 24Hz. 24Hz is now gone from the list above. Under SD/HD for 1920x1080 it now lists:
60Hz
59Hz
23Hz
Under custom it has 24Hz, when I click to customize this one it does not show the custom timing, but it is set to automatic, when I click to customize it is at 24.000
There are obvious skips when I set to 23Hz, so I'm pretty sure that it is not saving correctly. How can I save my 23Hz profile with custom 23.976 timing?
60Hz
59Hz
24Hz
23Hz
60Hz
59Hz
23Hz
