nvidia gtx 260 not detected
Chodam
I just built my computer, and everything works properly, except for my video card. It has power and the fan is moving. I installed the latest drivers, but it is still not being dtected, I can only use my onboard GPU. How can I fix this?
Possibly not enough power to run the card.
Its not practical to diagnose without knowing your hardware.
My power supply is a 630 watt 80 plus cetified.
3.1 AMD Phenom II B.E duel core
4 gigs of ddr3
Wirless card
GTX260 OC
500g harddrive
one Dvd read and burned
what motherboard are you running?
Look in your BIOS settings for an video option that you choose between Onboard or PEG/PCIe.
Also, make sure you plugged in the power connectors for the GTX260.
