So I finally set my 8800gtx up folding yesterday. Everything seemed to install fine and it was up and running - downloaded core 11 and said "F@H: Working 0/10000000" or whatever in the tooltray. Great, I figure. I opened the viewer just to see what it looked like and it was starting at 0 and said I had 4 hours to finish the first work unit.
Come back this morning and I notice it's on 1500/100000000 and I figure it must have finished the first WU and started another. Checking the log, though, and it appears it hasn't even finished the first one. Moreover, whenever I open the viewer, the progress starts back at 0.0000% and begins counting. Is this normal?
[15:06:48] Trying to unzip core FahCore_11.exe
[15:06:48] Decompressed FahCore_11.exe (1822720 bytes) successfully
[15:06:53] + Core successfully engaged
[15:06:59]
[15:06:59] + Processing work unit
[15:06:59] Core required: FahCore_11.exe
[15:06:59] Core found.
[15:06:59] Working on queue slot 01 [July 12 15:06:59]
[15:06:59] + Working ...
[15:06:59]
[15:06:59] *------------------------------*
[15:06:59] Folding@Home GPU Core - Beta
[15:06:59] Version 1.06 (Mon Jun 23 10:53:13 PDT 2008)
[15:06:59]
[15:06:59] Compiler :
[15:06:59] Build host: amoeba
[15:06:59] Preparing to commence simulation
[15:06:59] - Looking at optimizations...
[15:06:59] - Created dyn
[15:06:59] - Files status OK
[15:06:59] - Expanded 41215 -> 244433 (decompressed 593.0 percent)
[15:06:59] Called DecompressByteArray: compressed_data_size=41215 data_size=244433, decompressed_data_size=244433 diff=0
[15:06:59] - Digital signature verified
[15:06:59]
[15:06:59] Project: 5008 (Run 1, Clone 80, Gen 4)
[15:06:59]
[15:06:59] Assembly optimizations on if available.
[15:06:59] Entering M.D.
[15:07:09] Working on 576 p5005_supervillin_e1
[15:07:11] Client config found, loading data.
[15:07:11] Starting GUI Server
[15:34:58] Completed 1%
[17:43:51] Completed 2%
[20:59:26] Completed 3%
[21:06:39] + Working...
[22:59:47] Completed 4%
[01:01:13] Completed 5%
[01:55:46] Completed 6%
