That's what case fans are for? This card was not meant for some itty bitty SFF boxputer. The cooling from the pics looks much more serious and effective overall. Who knows if it will it be on the final version though?
I vote this pic for the best badassery involving an oem video card heatsink.
http://enthusiast.hardocp.com/image.html?image=MTIyOTU5MDAzNXNjRFphWklyZjJfMV8xMl9sLmpwZw==
I completely agree, i wish success to both ATI and Nvidia. Their never ending war will result only in better deals for us. I wish they keep on fighting...we don't want another Monopolysoft..do we?
I'm looking forward to power/heat.
Yawn! Kinda makes you wonder why people buy nVidia when ATI rules the roost. GPU's are king in the gaming dept. Why buy nV crap?
Yet ANOTHER super sucky stock cooling solution.
And dual PCBs.... ughhhh.
So...about how much can we expect GTX 260 to be after this launches?
I thought this card wasn't supposed to be made...it couldn't and wouldn't be done, the [H]ardforum experts said.
Couldn't be done with the 65nm GT200. This card uses the newer version of the GPU manufactured on a 55nm process, so power consumption and heat output is lower.I thought this card wasn't supposed to be made...it couldn't and wouldn't be done, the [H]ardforum experts said.
Can't remember if I read it in this article or in another, but you can indeed disable SLI to use all three ports.Are you limited to driving two displays with the card? or can you disable sli to power three with both DVI ports and the HDMI port?
Well how about two of these in quad sli? Can that drive 4 monitors then or still just two (and from which ports)?
Quad SLI with 4 monitors?
SLI enabled on one card, disabled on the other for 5 monitors?
Premature drivers most likely. It should improve greatly once Nvidia optimizes the cards performance. We won't have to worry about AMD to much longer anyways. There stock just keeps on falling . They have enough for probably 2 more revisions of there CPU/GPU line tops before they are tapped out of cash.
Giving the 9800GX2 only 512MB was a tragedy, and only 896MB on the GTX295 just says to me that nVidia didn't learn from that mistake. ATi learned that lesson, why didn't nVidia?
As far as I know, enabling any sort of SLI will limit you to two monitors. I'm not that up to date with nVidia's current drivers though, so I don't know if it's possible to run one card in SLI mode and the other in single-card mode (although to be honest, I wouldn't expect that to be the case).
however (and i asked about this above) it didn't seem clear to me from the article whether you have to disable the "internal" SLI on the 295 to use all three graphics ports, or if that only happens when you enable quad-SLI. probably the former, but one can hope.
I'm pretty sure you do have to disable the internal SLI to use all of the ports. Otherwise, you're limited to two of them.
I've been reading people saying that the fact the card vents back into the case via the top vents is crap. I say look at your case, and tell me if it's vented there. On my Lian Li A05, which is the entry model of Lian Li, there are vent holes above the PCI slots. Thus, my 9600GT, and this GTX295, can both vent heat OUTSIDE my case, and not into it. Just something to point out.
Thanks for the review Kyle and crew.
Serious question, at a pricetag of $499 is nvidia going to be selling these cards at a loss just so consumers don't go out an alternative which is ati's 4870x2?
