- May 18, 1997
Ctrl_Alt_Delete said:to get rid of the shimmering you just set go into the display settings, set the negative LOD bias to clamp and set the image quality to high. i run at 1920x1080 on my 24" sony and havent seen any shimmering or texture crawling since doing so. this fix has been around for quite a long time. i think its becoming more prevalent as average monitor sizes increase and more people notice.
EDIT: looks like i got this in seconds before Kyle posted below....
question for Kyle or Brent: have you guys tried the above? or do you do all testing at default settings?
From the page:
What do we think about this texture crawling issue? We dont like it and we hope NVIDIA makes some improvements with their filtering quality in their drivers soon. We are aware that you can force a higher mode of texture filtering by turning off some of their optimizations, but honestly wed like the default filtering quality to simply be better without having to turn off optimizations by hand in their driver control panel. Be aware that some folks are much more alert to this shimmering issue than others, so if you have not seen it, I suggest you dont go out and look for it.
Do understand that the reason NVIDIA leaves these harsh filtering optimizations on is two-fold. First, on smaller displays, it simply does not make a difference to the vast majority of gamers out there. Second, it gives NVIDIA based GPUs better benchmark numbers. And in the land of video card marketing, where the size of your ePenis score is king, you dont want to give up a few benchmark points lest you have the other team waving their ePenis back at you.
If NVIDIA is going to leave these optimizations on by default in the driver, and they are well aware that these optimizations negatively impact your gaming experience on larger displays, that is the ruler we are going to judge them by. We will continue to point out filtering issues where we see them impacting our gameplay.
