Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Just get a 6800 gpu block that uses adapters, that way what ever brand GPU you buy they're more than likely to make an adapter for the 7800 if it doesn't use the same as the 6800.
But yes only time will tell....
