I don't like Macs. I just want to make that clear. However, I find this interesting.
Apple is rolling out some new 30" Cinema Displays. They look great. They are saying you will need a NVIDIA GeForce 6800 Ultra DDL to run it. This card is Mac only.
"Driving Force
The 30-inch Cinema HD Display is so big, it requires the next level of graphics technology. The NVIDIA GeForce 6800 Ultra DDL graphics card delivers, with the most advanced graphics engine available for Mac. This card includes dual link DVI connectors to deliver up to 2560 by 1600 resolution over each port. Even better, with two connectors, or Dual Dual Link (DDL), you can drive two 30-inch displays, for the ultimate creative canvas. This $599 card will be available as a built to order option and as a standalone kit in August 2004."
"Dual Link DVI
The 30-inch Cinema HD Display requires the next level of DVI connectivity dual link to drive the massive amount of pixels to the screen. And the NVIDIA GeForce 6800 Ultra DDL graphics card (available from the Apple Store) delivers, with the most advanced graphics engine available. This card, designed specifically to support the dual link DVI connection, delivers 2560 by 1600 resolution. And with two dual linke connectors, it can drive two 30-inch Apple Cinema HD Displays, giving you the ultimate creative canvas. This card will be available for Mac only in August 2004."
So is this just a 6800 Ultra with dual dvi or what? or is this something different?
http://www.apple.com/displays/
btw, the reason I am asking is you can use the Apple Cinema displays on a pc as well
I am just wondering if a normal 6800 GT or Ultra would be just fine for it
"Driving Force
"Dual Link DVI
