Between the reviews, heat, and price point of the GTX480 I have to say fix the card, make it cheaper and I might be interested. I don't think this statement is unreasonable.
hd38xx series is proof it can happen just not soon enough.
...AMD on the other hand got down to brass tacks and asked the question "How do we improve the gaming experience today?" That resulted in Eyefinity. Personally I think that's the biggest thing to hit the gaming world in a long time. Yeah we've seen it from Matrox and through software before, but not like this. We've never seen it done this well. Their own GPU is a computational power house in itself. But first and foremost AMD seemed to have concentrated on the gaming experience in the here and now while NVIDIA seems to be playing two or three moves ahead.
Though truly only time will tell as to who actually made the right call. My guess is that when we find out we'll have another GeForce FX like fiasco, or an ATI Rage 128 as compared to the VooDoo cards of the day. One thing I am certain of is that for better or for worse we will be seeing Fermi derived GPUs for a very LONG time. Possibly as long as we've been seeing G80 variants.
Just to give an example,I set my GTX 285 at 70% fan speed when gaming. Even after hours of playing games like Crysis or STALKER,it rarely tops 60c. So 80c at 70% is quite a jump.
I see alot of complaints about the heat on the card with the review and the comments here.. but no mention (unless I missed it) of atleast a couple reviews now saying that if you manually set the control speeds for the fan to 70% it'd run under 80c (and if you could live with the noise running the fan at 100% then it'd be in the mid 60c range). According to Overclockers club atleast and if I'm not mistaken that was with the card OC'd quite decently.
Maybe there will be drivers to fix the issues.. or maybe it just goes to show how much NVidia believes that the card can handle these temperatures. Its obviously not an issue with the card not being able to deal with the heat.. its just trying to do it in the most noise free way possible. I'd have to question if that decision may somehow hinder the ambient temperatures of the case and thus effect the OC ability of for instance the CPU, but if that's the case then there's always manually setting the fan speed.
If that's 3-way.. what would 4-way look like since they've announced that now?
Where does GTX480 performs "just as well" as 5970 ? GTX480 performs a bit better than 5870, but it is pretty far from 5970.
Except they're not doing apple to apple comparisons.. all [H] showed is that you can get higher image quality by running higher AA with a 480 over the 5870 and get the same framerate.
Where you say the 5970 has better resolution look at the AA settings on the two which is also doing very high btw.. only thing doing high is the 470. You can't make any comparisons by [H]'s benchmarks on how the single 480 compares to the 5970.
while that might appear true please remember also this other [h] that show there is image quality drops when there is 4x AA and very high is selected. so really it acting more like high well until game dev patch it. which is what i am implying when i said it was working as high. while apples to apples is not available by [h]. Clearly they should have some more than marginal performance gain verses the 480 with almost a drop of almost 1/2 the resolution. Also metro 2033 has already been optimized for the 480 as it TWIMTP games. while ATI now has to release drivers update to optimize the rendering of it.
Actually that says NVidia is effected by AAA.. with 4XMSAA theres no image difference between the 400 and 5000 lines. Then goes on to say both lines are effected by 4XMSAA. So either way 4XMSAA seems to be a better way of comparing both cards atm still making the above benchmark I showed have some merit. And yeh as I said before ATI obviously will get their framerates up more and have the 5970 surpass the 480 at lower resolutions, but that gap in the higher resolutions makes it hard to believe any sort of drivers could close that much.
And atleast according to PC Perspective NVidia holds the only single card (be it dual GPU or not) that can run Metro 2033 with all the bells and whistles on and still have a game that doesn't look like a slideshow.
Anyway the 480 has shown it can compete with even the 5970 if the game is making use of certain features that the NVidia gave up raw pixel pushing power to do other things like geometry tessellation much more efficiently. The majority of games that's obviously not the case atm, but at the same time there is such a thing as overkill and 60+FPS there is just absolutely no way of noticing any difference so your paying more for no real gain. That's all I'm trying to say. ATI's current architecture might of been the first to provide DX11 but hardly do it in an efficient manner. Though really only time will tell if more games come.. I'm guessing NVidia isn't gambling though since their support to developers early on means they can help push games to make use of their card more.
Agreed, but that 80c is with it running Furmark which is way more demanding on the GPU then any game is. While I doubt it'd be running at 60c or maybe even 70c its hardly the 95c that everyone quotes from reviews if it manually set (at a reasonable noise level) rather then auto controlled.
This. But I've only been saying this kind of thing for about, oh, I don't know, the last 6 months maybe? Why should anybody listen?While I typically prefer [H]'s qualitative reviews over raw quantitative comparisons, this methodology can be flawed, and I think we have a glaring example of this flaw in the latest review.
[H] concludes that GTX 470 is a waste of money and has no real purpose compared with the competition. It performs on par with the 5850, they argue, and since it costs more and runs hotter, it makes no sense.
Now here's the flaw: since [H] only tests cards at their highest playable resolution, you see the GTX 480 and 5870 usually running at 25x16, whereas you see the GTX 470 and 5850 running at 19x12. For the majority of gamers, who are running at 19x12, this is not necessarily the most useful comparison: it would be far more instructive to see what *all* the cards can do at the same 19x12 setting.
