Nvidia Drivers will not install
dclamage
I'm trying to remain as calm as possible, but so far that's a bit of a struggle.
My new 8800GTS 512 arrived 4 hours ago. Physical installation was a breeze. Removed all the drivers and registration keys and excess files for my old ati card and rebooted with the new nvidia. No problem, at least not initially.
The first thing that I noticed wrong was that the PnP was not detecting the card as an nvidia 8800gts. Rather, it lumped it in as a generic vga. I figured, OK, it will probably change when I install the drivers...
Every single time at 50% of "installing driver components" the install stops for no particular reason whatsoever. Trying to reinstall it tells me that I'm not even running vista 32 bit, which I am. BFGtech support couldn't give me a solution, so now I am posting here.
Hardware
Asus P5N-E SLI 650i chipset (BIOS updated to 803)
Intel C2D E6750 @2.66GHz
2Gb (2 x 1Gb) Corsair XMS2 DDR2-800
600W PSU
Windows Vista Business 32 bit
The error codes
Code:
Fault bucket 188870004, type 5
Event Name: PnPDriverInstallError
Response: None
Cab Id: 0
Problem signature:
P1: x86
P2: 000005B4
P3: nv_disp.inf
P4: 829925d01f068b749da4aabaadc17e98b4bdcab2
P5: nv_NV3x
P6:
P7:
P8:
P9:
P10:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report03015b1a\DMI4ECB.tmp.log.xml
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report03015b1a\oem22.inf
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report03015b1a\WER5216.tmp.mdmp
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report03015b1a\WER5275.tmp.hdmp
These files may be available here:
Response: None
Cab Id: 0
Problem signature:
P1: x86
P2: 000005B4
P3: nv_disp.inf
P5: nv_NV3x
P6:
P7:
P8:
P9:
P10:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report032c0741\DMIFAC9.tmp.log.xml
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report032c0741\oem22.inf
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report032c0741\WERFE43.tmp.mdmp
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report032c0741\WERFEA1.tmp.hdmp
Fault bucket 189388818, type 5
Event Name: PCA2
Response: None
Cab Id: 0
Problem signature:
P1: 169.25_forceware_winvista_32bit_english_whql(2).exe
P2: 4.0.100.1190
P3: unknown
P4: NVIDIA Windows Vista Display Driver
P5: NVIDIA Corporation
P6: 1
P7: 201
P8:
P9:
P10:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Report0848340a\appcompat.txt
My great thanks to anyone who can help me resolve this in a timely fashion.
2 tips:
remove the video card, and use your ati card to go into windows vista, and go to device manager and "remove" the display adaptor.
go into safemode, and run the driver cleaner again.
if this does not work try re-installing windows vista.
if this does not work, try asking yourself hte following questions:
do i have enough power? atleast 450W PSU recommended.
is the power connected to the video card?
is the video card SEATED properly in the PIC-E lane (push it down a bit more)
that is all i can think of ATM
If I do a reinstall can I just have it reinstall the windows core files? In other words, do I need to worry about losing all my documents?
The reinstall did it! PnP picked up the card flawlessly, automatically installed the latest forceware drivers. Thanks for the help!
As far as Im concerned you would have to reinstall programs...they write info to the registry and might have additional files located in the Windows directory...reinstalling windows uses a new registry and new Windows file...your programs will not work without all the old stuff.
