About 2 years ago, I ordered ABIT KN9 AM2 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16813127010
It has been good to me over the years but my hard drives have not so one day I had to reformat and I grabbed my old Win XP Pro cd, one of the old original cds and it was too scratched to use. So I got my laptop and downloaded Win XP Pro SP3(Vista Style) from a torrent which was highly rated on isohunt.. I burned it and installed it on my computer fine but when I tried to use the original motherboard cd to install, nothing would install. I would keep getting errors saying install SP2 and other stuff. I downloaded all the updates and for some reason I downloaded SP1, 2 and 3 even though I was supposed to be on 3..
I heard that XP, you can skip service packs or so. Anyway, on my older original Win XP CD, my motherboard drivers worked but not on this. The CD is not scratched for the mobo drivers and the files work but I can't get my drivers to work so I can't get online since my integrated NIC is what I use. It lights up if I put a cable in there but Windows won't detect anything and when I install the cd, it usually takes like 60secs to install the drivers but it literally takes 1 sec and says it is complete installing and to restart the computer.
My mobo is older so I guess it was designed for SP1 or even before SP1 came out..??
also, will my win xp pro cd key work on a win xp home edition?
