Doozer
- May 30, 2001
Which drivers are you guys using for best PPD?
Oh yeah, I'm running a couple of GTX275s on windows 7.
To be honest, I know nothing about the new drivers or versions released after winter. I'm aware that drivers over the 180s see a drop in performance, which is why I'm still using 170s. I do not know if the performance has picked up with newer releases in the last 6 months, though. Hope someone who has more info can post about it because I'd like to see a performance boost with all the nVidia hardware I have running.Yeah, there are new ones. I just was wondering if anyone had a better PPD output with a certain version.![]()
I have the v178.24 drives on one of my four nVidia GPU systems. All the others are using v177.89 and I see absolutely no difference with any WUs between the two driver sets. All my nVidia cards are 8800GTs and the OCs are the same except for one system that has two dual-slot cards which could run higher frequencies.I think, and this was just my personal experience, the 178.24 was the best driver. Right now I'm using the 190.62 since the 178.24 isn't available for Win7. Numbers seem almost comparable (from what I remember), but also the WU have changed, so I really don't have any direct comparison.
^^ Can someone confirm that? That would be awesome to leave it in SLI and still fold, then I'd need not bother with switching back and forth and mem usage would also be down 50megs or so
I'm pretty sure you still have to run two GPU clients. The only difference is that CUDA can now access individual GPUs when running an SLI setup, so you don't have to disable SLI to fold on both cards.i believe with the newest nvidia drivers in windows 7 you no longer have to run 2 gpu clients.. since cuda is now scale-able across 2 or more GPU's.. so you can leave the cards in SLI.. there is little to no difference in PPD with the drivers though from one version to the other..
I think that should work as well.so you can leave it in SLI? what about bastard configs, like 3 cards but only 2 are in SLI, third is Physx? (All 3 are 260's I just dont have a tri-sli board)
