Nvidia Driver 616.92 September 9th 2026
Comixbooks
Our new GeForce Game Ready Driver optimizes your system for 007 First Light’s path tracing upgrade, adds support for PUBG’s forthcoming DLSS Super Resolution update, and gets you Game Ready for Active Matter, Aniimo, and WARDOGS, three new DLSS games launching in the near future.
Download the new driver through NVIDIA App , or from GeForce.com .
Click below to learn more:https://www.nvidia.com/en-us/geforc...-light-path-tracing-geforce-game-ready-driver
Fixed Gaming Bugs: N/A
Fixed General Bugs:
  • Intermittent flicker may be observed in browsers when navigating to certain websites [6673430]
  • Fixed an issue where virtual displays could not be created after updating to driver 616.56 [6674464]
  • Remote Desktop Protocol (RDP) sessions may display a black screen after updating to driver 616.56 [6687328]
Open Issues
  • “Prefer Maximum Performance” Power Management Mode may not be applied correctly [6007998]
  • Assassin's Creed Shadows may crash to desktop after extended gameplay after updating to driver 616.56 [6685219]
Game Ready Driver v616.92 Release Notes - Click Here
Troubleshooting and providing driver feedback:
No issues with this driver so far, but I'm still playing an older game (Jedi Survivor).
Same as the hotfix driver. Still seems bugged for Edge with hardware acceleration on (flickering), but Chrome seems fine.
I'd just installed the 616.86 hotfix driver, rebooted and this popped up. Installed and all good so far.
new DLL's out now too: https://www.techpowerup.com/download/drivers/
v310.9.1
Key Updates and Changelog
    • Ray Reconstruction Preset F: Officially adds support for the DLSS Ray Reconstruction Transformer Mode under Preset F.
    • Vulkan Low Latency 2: Integrated native support for Vulkan Reflex via the VK_NV_low_latency2 extension to lower system latency.
    • Dynamic Multi-Frame Generation: Added support for VSync when DLSS Dynamic Multi-Frame Generation is active.
    • General Fixes: Included general bug fixes, engine crash resolutions, and stability enhancements. [1, 2, 3]
I need to try this. I've got some flickering on YouTube videos that I can't fix. Nothing major, just annoying.
You can either turn off hardware acceleration or set Angle to D3D11 WARP. It forces your CPU to do browser rendering in Chromium browsers but should stop the black screens. Or you could use non-chromium browsers - Firefox or Zen browser for instance.
What sites have this issue? I upgraded both my desktop and laptop but haven't encountered it yet, and I run Edge.
On Edge I get black screens when trying to log into paypal.com website. It goes away with either hardware acceleration turned off or edge://flags ANGLE backend set to D3D11 WARP.
Huh. I logged in, no issues. Using Edge on Win 11 with 626.92 installed. WTF?
Do you have VRR enabled on a HDMI 2.1+ display?
Oh is it HDMI only? I have VRR on, but on DP 1.4 (PG32UCDP).
Edit: One other thing I've done is disable multi-plane overlay, to fix VRR flicker from hardware accelerated apps in Windows. It doesn't disable acceleration entirely from my understanding, just the direct access. I did that quite awhile ago since various plugins in Nuendo caused issues. "reg add "HKLM\SOFTWARE\Microsoft\Windows\Dwm" /v OverlayTestMode /t REG_DWORD /d 5 /f" is how you disable it.
Second edit: Disabling MPO does sound like it should fix it. Also apparently changing your output bit depth to 10-bit might fix it? No idea why, but no real reason not to if your display supports it.
I've tried the hardware acceleration thing but it makes it look choppy. It's not too terrible. It's only when I move the cursor over the progress bar, it'll flicker. It's weird but not anything I can't live with. Maybe I'll try Firefox. I haven't used it in eons lol
